Query String question
Thread began 4/05/2011 7:56 am by Paul | Last modified 4/05/2011 11:04 am by Jason Byrnes | 1207 views | 3 replies |
PaulBeta Tester
I have a DA created update page, where i've taken the following from;
// WA Application Builder Update
if (isset($_POST["Update_x"])) // Trigger
$WA_connection = ********s;
$WA_table "********l";
$WA_redirectURL "results.php";
  if (
function_exists("rel2abs")) $WA_redirectURL $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString true;
$WA_indexField "propM_id";
I have changed KeepQueryString from False to True but dont want 'propM_id' as the query string, where/how do i change this to 'pid'?
Thanks, Paul.
if you want the quesrystring that is passed out to have a different name, then you need to use that name on the quesrystring that is passed in.
the keep querystring option cannot rename the querystring variable.
PaulBeta Tester
Thank you.
you're welcome.
