Shorter Invoice Numbers?
Thread begun 6/29/2009 5:49 pm by vela1606379889 | Last modified 11/25/2009 7:05 am by Ray Borduin | 2619 views | 3 replies |
vela1606379889
Hello!
This should be an easy one. When I process my test order I get a ridiculously long invoice number. Is there somewhere that I can set a starting point for that? It seems like it is generated by e-cart somehow, but I'm not sure where. The invoice number I get looks something like this 3516f673771283362933 which is a bit cumbersome.
Best,
E
Use the orderID from the orders table instead. It is already stored and can be displayed in place of the sessionID (which is what this number is).
nunez_r336980
I'm using a static page, so I don't have any tables. Is there a way I can configure the invoice number? I'm using ecart with the authorize.net AIM implementation.
Probably not without some hand coding. You could maintain a text or xml file with an invoice number and write a script to increment it, but the only readily available unique number without a database is the sessionID that is what you are currently seeing.
