Warning - Can't login to admin_gallery
Thread begun 4/04/2011 8:13 am by farnumfoto279323 | Last modified 4/05/2011 10:33 am by Jason Byrnes | 3733 views | 4 replies |
farnumfoto279323
I went to login to PowerGallery to continue to work on mt web site and I got these warning messages:
Warning: fopen(Connections/installed_gallery.txt) [function.fopen]: failed to open stream: No such file or directory in /hermes/web04/b185/as.douglasstephen/public_html/powergallery/admin_gallery/images/installed.png on line 15
Warning: filesize() [function.filesize]: stat failed for Connections/installed_gallery.txt in /hermes/web04/b185/as.douglasstephen/public_html/powergallery/admin_gallery/images/installed.png on line 16
Warning: fread(): supplied argument is not a valid stream resource in /hermes/web04/b185/as.douglasstephen/public_html/powergallery/admin_gallery/images/installed.png on line 16
Warning: fwrite(): supplied argument is not a valid stream resource in /hermes/web04/b185/as.douglasstephen/public_html/powergallery/admin_gallery/images/installed.png on line 18
Warning: fclose(): supplied argument is not a valid stream resource in /hermes/web04/b185/as.douglasstephen/public_html/powergallery/admin_gallery/images/installed.png on line 19
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /hermes/web04/b185/as.douglasstephen/public_html/powergallery/admin_gallery/global.php on line 37
Warning: Cannot modify header information - headers already sent by (output started at /hermes/web04/b185/as.douglasstephen/public_html/powergallery/admin_gallery/images/installed.png:15) in /hermes/web04/b185/as.douglasstephen/public_html/powergallery/admin_gallery/index.php on line 6
photoeyes2u348674
Originally Said By: farnumfoto279323
I am having the same problem with the same error messages with my own info. Can't log in again. This happened recently with the same error messages. It seems this is a recurring problem that is not solved. Are we going to have to go through this periodically?
I had to download a fresh powergallery and go through my galleries again. I would have to see the sequence of events but it is annoying and time consuming. Help??
here is a new copy of the installed.png file to correct the problem, copy it to the following folder in your site:
also, edit the admin_gallery/global.php file, change lines 34 - 37:
require_once("images/installed.png");
//PowerGallery version
$wa_settings['pg_version'] = '1.2.0';
mysql_free_result($result);
photoeyes2u348674
This solved the problem. Thanks.
glad to hear it is working.
