Undefined index: eCart_AusPost_Quote
Thread begun 4/03/2011 6:11 pm by Lee Firth | Last modified 4/05/2011 7:38 am by Jason Byrnes | 2225 views | 5 replies |
Lee Firth
When I add an item to the cart I following error appears:
Notice: Undefined index: eCart_AusPost_Quote in C:\inetpub\wwwroot\my_life_rulz_ecart\WA_eCart\eCart_PHP.php on line 103
I realise that this is a session variable $_SESSION['eCart_AusPost'] that isn't being set, but I cant work out why.
In the eCart object I have the Shipping trigger set to if "Total number of items > 0" which means that shipping should be applied if there is any items in the shopping cart.
how does that session variable get set?
it probably gets set on the confirm page. So it is not set when the item is added to the cart.
if the session is being used as part of the calculation, you should add If session variablke exists to the shipping rules trigger section so the trigeer will be:
Session variable eCart_AusPost exists
AND
Lee Firth
Other issue shipping calculation not being performed
Thanks Jason, adding that additional trigger did the trick, although I have another issue now. The shipping doesn't calculate. I've traced where this is done on the confirm.php page, this is the if statement that starts the shipping calculation:
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))
Now if I remove the middle two triggers:
It works.
I've done a little more research and this line of code is asking if the page you are at, in my case this is "localhost/my_life_rulz_ecart/confirm.php" is NOT the same as where you came from, in my case this was "http://localhost/my_life_rulz_ecart/checkout.php" then don't perform the shipping calculation. Seems to me the opposite should be true.
that is the current page submit trigger, you should be using the any form post trigger.
Lee Firth
Doh!
Thanks Jason.
No worries.
