Validate form elements on checkout page
Thread begun 6/29/2009 2:18 pm by grantr281040 | Last modified 9/29/2009 11:26 am by Jimmy Wu | 7367 views | 13 replies |
grantr281040
Hey Ray!
A couple of years ago I was using coldfusion, and had this question and during a mentor session, and you showed me a quick way to validate some of my form items before bad info can be passed from the checkout page to the confirm page.
If bad info was entered a small dialog box popped up and would not allow the page to be submitted.....so if for instance an email address was not valid or if a cvv code was not entered or if the cc number was not the correct amount of digits.
Now I have moved to PHP and it has been a while and I cannot remember how we did it. I think it was some type of form action but I don't even know where to start.
Any ideas?
Grant
These days the best way in my opinion is to use spry and webassist validation toolkit server validation. At the time we used, and you could still use, webassist client validation, which is also part of validation toolkit.
grantr281040
I thought it was just some sort of code that triggered a dialog box to pop up but looking at it now it appears to be a WA thing. As I remember....it was a very quick an easy thing...(for you anyway). I think this is it in my old coldfusion code in my checkout page. I guess I should stay away from spry right now as I know nothing about it.
How would I recreate this same type of scenario in php? Is there some sort of tutorial somewhere? Sorry for the questions but I'm not sure how to implement this.
I assume I do it on the checkout page and add a serverbehavior with the "+" button? and then to validation toolkit and then to server validations?
If that is correct....then it should be triggered by..."current page submit"?
"validation type" looks self explanitory and then
how can I determine the "server variable"?
and what goes in the big box with the "+" button above it...is that the message that appears when it is an invalid entry?
"failure redirect" I assume should be the same checkout page? (Return to the same page to reenter the information?)
<form action="confirm_cc.cfm" method="post" name="ecart_checkout_form" onsubmit="WAValidateCC(document.ecart_checkout_form.cc_number,document.ecart_checkout_form.cc_number.value,'- Invalid credit card number','','4:51:52:53:54:55:34:37:6011:',document.ecart_checkout_form.cc_number,0,true);WAValidateEM(document.ecart_checkout_form.email,document.ecart_checkout_form.email.value,'- Invalid email address',document.ecart_checkout_form.email,0,true);WAValidateRQ(document.ecart_checkout_form.cvv,'- CVV Entry is Required',document.ecart_checkout_form.cvv,0,false,'text');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,false);return document.MM_returnValue">
Thanks!
Grant
You should follow the samples and tutorials provided. You have so many questions my quick response couldn't do it justice. It appears you may need the getting started guide provided to get a general idea of the concepts involved.
Don't be afraid of spry. It is very simple to use in CS3 and CS4 (CS4 has additional options).
grantr281040
You were right...I looked around and found what I needed in the tutorials. What I needed to do to solve this one was to go to insert> WebAssist> Validation Toolkit> Client Validation.
That brought up a dialog box that asked me which "form" to validate and then walked me through a simple wizard to complete the task. VERY EASY!
SOLVED...THANKS!
MeyerJ196339
I have been searching and reckon this thread is the closest to what I need!
I want to validate the credit card and billing address fields in checkout.asp (created by the eCart wizard). I applied server side validation to the confirm.asp page and it works brilliantly. My only problem is that I am returned to the checkout.asp page (quite correctly) but I can't work out how to display an error message on that page to the user. Is this possible?
Jimmy Wu
You will have to write out the error message on the page and then apply a Validation show if behavior to that error message.
MeyerJ196339
Thanks Jimmy. I don't suppose you could show me a vbScript example of how to write out the error message (or point me in the right direction), could you? I know how to do use the show if behaviour, but I'm unfamiliar with "writing out" an error message
MeyerJ196339
Originally Said By: MeyerJ196339
Thinking about it, maybe you mean saving the errors to a session variable and testing against this in th checkout.asp? I'm a complete amateur so perhaps it's the terminology that's confusing me?
Jimmy Wu
Sorry about not being clear. You put what you want as the error message onto the page in the position you want it to show up. You can do this in design view so that its easier to visualize if you're not strong in coding.
After adding this to the page, you will have to highlight the message and apply the validation show if server behavior. Specify which validation will cause the error to show up and apply it. This will cause the error to only show up if that particular validation fails.
