editing search
Thread begun 4/01/2011 1:47 pm by turk361661 | Last modified 4/11/2011 8:36 am by Jason Byrnes | 4682 views | 9 replies |
turk361661
editing search
Editing a Search.
I have a Search Page that has 3 search box fields for searches by Name, Common Name, and Category. I want modify the Search so that it is only one Search box field. Using this single search box users can type in a the name or common name and it will search both columns in my database. (I'm removing Category all together).
Any advice on modifying?
Is there a way I can open and edit the Search with DataAssist. (I created it with DataAssist)?
Also, my code is attached for reference.
Thanks,
Danielle
to edit the search criteria, double click the DataAssist search server behavior on the results page.
remove the criteria you no longer need and edit the Name Criteria. the columns section is a multi select list, select all of the columns you want to search against.
turk361661
I'm still missing something.
See code attached for search (I removed the additional fields) and Results (I updated the server behavior).
The Results page server behavior now includes the ProductName and ProductCartDesc columns. I had to choose the type as "keywords" because I now have two columns selected.
When I try to search. The Results page shows all products listed in my database.
It should show only close matches (does not have to be exact).
Something is off. See code attached.
thanks for your help,
Danielle
on the results page, change:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["S_ProductName"]))?$_POST["S_ProductName"]:"")  ."","OR","Includes","%20AND%20","%20OR%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_GET["S_ProductName"]))?$_GET["S_ProductName"]:"")  ."","OR","Includes","%20AND%20","%20OR%20","%22","%22",0);
turk361661
Hi Jason,
I made the change. It is still pulling all products in the database.
See code attached.
Thanks for the help,
Danielle
the recordset code on your page is duplicated. delete lines 109 - 113
mysql_select_db($database_connNCP, $connNCP);
$query_WADAproducts = "SELECT ProductID, ProductLight, ProductName, ProductPrice, ProductWeight, ProductCartDesc, ProductShortDesc, ProductLongDesc, ProductThumb, ProductImage, ProductCategoryID, ProductUpdateDate, ProductNew, productMoist, productWood, productDeer, ProductLive, ProductUnlimited, ProductLocation, ProductsEnvironmentID FROM products ORDER BY ProductName ASC";
$query_limit_WADAproducts = sprintf("%s LIMIT %d, %d", $query_WADAproducts, $startRow_WADAproducts, $maxRows_WADAproducts);
$WADAproducts = mysql_query($query_limit_WADAproducts, $connNCP) or die(mysql_error());
$row_WADAproducts = mysql_fetch_assoc($WADAproducts);
turk361661
Hi Jason,
That fixed it!
One more question.What option would I choose to have the results page include "close" matches.
For example. A user misspells a product name, say "LILLIUM", in the search box.
This will return zero products because of the misspelling of the name (The correctl spelling is "LILIUM")
Is there a selection I can make so that "close" matches show up on the results page?
Danielle
No, the SQL Query language does not offer support for the type of close matches you are describing.
turk361661
This post has been deleted.
turk361661
Hi Jason,
Regarding my message back on the 4th, That fixed it.
It is working well with the exception of IE8 running on a PC (Windows Vista or older).
Any idea why IE8 would pull search results differently. This makes no sense to me.
Code and links attached.
Example:
go to link in text file. In the search box, enter
fern
Click Search.
In fireFox it shows 18 results containing fern.
In IE8 it shows 679 results (pull everything in the database).
Danielle
