Multiple Domain API-Codes don't display
Thread begun 4/01/2011 12:49 am by info346215 | Last modified 4/06/2011 7:51 am by Jason Byrnes | 4818 views | 5 replies |
info346215
Hello,
Ma client has two domains www.dr-jürgen-voigt.de and www.dr-juergen-voigt.de.
As I need 2 API codes, I inserted them as showed in google help and some forums, but it doesn't display with promaps configuration.
Attached find (1) the functioning code for 1 api (functioning) and (2) the snippet for the possible solution.
How is it to be done?
Thanks for fas reply and best regards
kluthwalledesign
(1)
<html xmlns="http://www.w3.org/1999/xhtml" xmlns:v="urn:schemas-microsoft-com:vml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<!-- TemplateBeginEditable name="doctitle" -->
<title>Zahnarzt Dr. Jürgen Voigt Krefeld • ANFAHRT</title>
<!-- TemplateEndEditable -->
<!-- TemplateBeginEditable name="head" -->
<script type="text/javascript" src="google_javascript/wagmp_map_1.js">/*wagmp*/</script>
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAmbJ2WJ7JRpfnx7gQZQ8tOxSCM3qo1s5a3CnYyocOPEFF-xvtfhRh0ImbFSmiHFORieQGoCK9QJw9og">/*wagmp*/</script>
<link href="fav_voigt.ico" rel="SHORTCUT ICON" title="Favicon" />
<link href="CSS/voigt.css" rel="stylesheet" type="text/css" />
<!--[if IE 5]>
<style type="text/css">
/* Fügen Sie CSS-Box-Modell-Korrekturen für IE 5* in diesen bedingten Kommentar ein. */
.thrColFixHdr #sidebar1 { width: 180px; }
.thrColFixHdr #sidebar2 { width: 190px; }
</style>
<![endif]--><!--[if IE]>
/* Fügen Sie CSS-Korrekturen für alle IE-Versionen in diesen bedingten Kommentar ein. */
.thrColFixHdr #sidebar2, .thrColFixHdr #sidebar1 { padding-top: 30px; }
.thrColFixHdr #mainContent { zoom: 1; }
/* Mit der obigen proprietären Zoom-Eigenschaft wird IE die Eigenschaft hasLayout zugewiesen, die zur Verhinderung verschiedener Fehler erforderlich ist. */
</style>
<![endif]-->
</head>
(2)
<script type="text/javascript"> document.write( &#8232;* * * '<script src="http://maps.google.com/maps? &#8232;file=api&v=2&key=' + &#8232;* * * { &#8232;* * * * 'dr-jürgen-voigt.de': 'ABQIAAAAmbJ2WJ7JRpfnx7gQZQ8tOxSCM3qo1s5a3CnYyocOPEFF-xvtfhRh0ImbFSmiHFORieQGoCK9QJw9og',
'dr-juergen-voigt.de':'ABQIAAAAmbJ2WJ7JRpfnx7gQZQ8tOxSGzBORnT2x4UzbHRp1weuX7_URARSLfM2LTnC21CdL9wSU7QfVAM0tmA',&#8232;* * * }[location.host] + &#8232;* * * '" type="text/javascript"><\/script>' ); &#8232;* *</script>
convert your map page to a php page and use php code to generate the api key:
switch ((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:"") {
    case
"domain1.com":
$key = "key1";
        break;
    case
"domain2.com":
$key = "key2";
        break;
   case
"domain3.com":
$key = "key3";
        break;
   default:
$key = "key1";
        break;
<script type="text/javascript"  src="http://maps.google.com/maps?file=api&v=2&key=<?php echo $key; ?>">/*wagmp*/</script>
info346215
Clinet has serverplace without php
Thank you for your php-solution, but my client booked a basic server place without the possibility of performing php-pages.
Do you know another solution for displaying mutiple domian apis? (Forcing one domain?)
Thank you very much.
kluthwalledesign
can you post a link where you have tried the javascript that is not working?
info346215
Made workaround- but IE doesn't display
As my client has no php-compatible serverplace, I doubled the website's host file and made one website for each domain with the different API-code for each domain separately.
It functions, but doesn't display in Internet Explorer.
Please give me a solution how to display in IE.
Thank you in advance!
kluthwalledesign
Here the code for dr-jürgen-voigt.de
<head>
<!--[if IE 5]>
</style>
</style>
<![endif]-->
</head>
please post a link to the map page.
