not a valid MySQL result resource
Thread begun 3/31/2011 4:24 pm by info13749 | Last modified 4/07/2011 11:15 am by Jason Byrnes | 4355 views | 7 replies |
info13749
Hi I created an email form spent some time testing and all went OK.
Whether its relevant or not, I moved the file and applied the security assistant to it.
Now when I run the form I get
Warning: mysql_free_result(): 3 is not a valid MySQL result resource in D:\hosting\3756774\html\moshpty\admin\email.php on line 154
This appears after the scrip runs, the emails come through OK
The line it refers to is
mysql_free_result($rsSchools);
Any ideas
Cheers
comment that line out:
//mysql_free_result($rsSchools);
either the recordset does not exist, or the result set is being cleared elsewhere in the script.
info13749
Thanks for the reply and sure I can comment it out it's only clearing of resources but I suppose that's not the point.
The recordset does exist and its the data that drives the email. The point is the error is being created by only applying your wizards to the the data. If its being cleared out its being cleared out by webassist coding.
I've just had a further look into it and its being cleared in the waue file associated with the email.
cheers
I have logged this as a bug, but the workaround is still the same, comment out the line that is causing the error.
info13749
Hi Jason, I commented out the line, and as expected no more warnings. I've now added a recordset loop for the email addresses and I get
Warning: mysql_fetch_assoc(): 2 is not a valid MySQL result resource in D:\hosting\3756774\html\moshpty\admin\email.php on line 123
Line 123 refers to an array of recipients
Cheers
Please send a copy of the email.php file.
info13749
Thanks - find attached
