Price Range Search Not Error
Thread begun 3/31/2011 7:18 am by hbibizadeh396670 | Last modified 3/31/2011 1:56 pm by hbibizadeh396670 | 4125 views | 8 replies |
hbibizadeh396670
I am developing a estate agent website for a client and have run into a problem with creating a price range.
I made the overall system, insert property information etc.. But I need to use the data assist search wizard to make a min and max price range search.
Although I think it did it correctly after I search I get these errors.
Notice: Undefined index: S_MinPrice in C:\wamp\www\RealEstatePro\AdminPropForSale\property_Search.php on line 19
Notice: Undefined index: S_MaxPrice in C:\wamp\www\RealEstatePro\AdminPropForSale\property_Search.php on line 20
Not sure what this means
Thanks in advance
please send a copy of the search and results page in a zip archive so I can examine the code.
hbibizadeh396670
Here thanks
1) Delete the DataAssist search behavior from the searchpage, it should only be on the results page.
2) Change the forms action on the search page to go to the results page:
<form action="property_Pesults.php" method="get" name="WADASearchForm" id="WADASearchForm">
hbibizadeh396670
Ok it did it.
Although I am not getting any errors I am also not getting any results at all
I dont know why
your search form has a number of select list on it that dont have any values. for example:
<select name="S_BedRooms" id="S_BedRooms">
</select>
these are being caught by data assist search and treated as null. to have DataAssist search ignore them if a valueis not selected, you need to have a default empty option:
<option ="">Make a selection</option>
</select>
hbibizadeh396670
I think I did somthing wrong.
I have given all my search menus have options. But I still dont get any results.
I deleted the seach form from the results page and loaded it on its own. When I do that I see everthing.
However when I search, using the search page, I get no results returned at all
I will need to see this in a browser to trouble shoot further.
hbibizadeh396670
I think I can work it out thanks
