JavaScript errors on inserting new menu
Thread begun 3/30/2011 10:07 am by tigger0995 | Last modified 3/30/2011 1:50 pm by Jason Byrnes | 2499 views | 3 replies |
tigger0995
I have been using CSS Menu Writer 2 for some time now with no problems. Today I tried to insert a new menu into a site and got the following two error messages:
While executing onResize in WA_SiteTools_Progress.htm, the following JavaScript error occurred: In file "WA_SiteTools_Progress": refreshUI is not defined
I click OK and get this message:
Error generating menu (wa.generate.menu):
TypeError: MM.WA_createProcessingObject is not a function
Any thoughts on a fix?
Delete the Dreamweaver Cache file from the users configuration folder:
tigger0995
Thanks, that worked. I forgot about that trick!
you're welcome.
