existing form
Thread begun 3/30/2011 7:13 am by turk361661 | Last modified 4/04/2011 9:01 am by Jason Byrnes | 4129 views | 7 replies |
turk361661
existing form
Hello,
I have an existing form that I used form builder to create a couple years ago. The name, email address, and comments field are all required fields.
Now I want to modify it so that all fields are required to be filled out.
How can I use form builder to make this type of update?
Or what areas of the code need to be modified to make this update.
Attached is my code.
Thanks,
Danielle
Simplest way to achieve this is to edit the Server Validations Server behavior and add required validation for the three additional fields.
Go to Window -> Server behaviors.
double click the Server validation server behavior.
From the validation type, select Required / not Blank / Selection made validation.
Click the lightning bolt next to server variable and select the Address form element, then click the plus button to add it to the list of validations.
repeat for the other elements that you wish to add, then click ok.
turk361661
Jason,
Something still off. See attached code.
I only added the Address field as a required field. However the page is not working correctly.
My goal is to make everything users fill out on the form be:
1. Required / Validated
2. Have text display if they forget to fill out the field (Please provide your "ABC")
3. Have the information display on the form that gets emailed to my client.
Possibly I need to start over from the beginning for this type of request.
But I was hoping to just add the rest of the fields (Address, Business, etc.) and make them required similar to the Name, Email, and Comments.
Thanks for your help,
Danielle
i think the problem is that this was originally created with a different version of Form Builder.
First, delete this line from the page:
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
then double click the Server Validation Server Behavior to add any additional validations.
Next, in the server behaviors panel, double click each of the validation show if behaviors, to reset them to the validation that trigger the error.
Add any additional validation show if behaviors you need to show other errors.
For each form element, rebind the initial value to the corresponding validated entries binding.
turk361661
Jason,
I'm so close to having it figured out but still something is off.
I made the modifications. Form loads correctly.
But When I fill out all the fields, the page reloads and three fields are empty. Each have the red text requesting that I fill out the info.
The fields are the Business Name, Phone, and Fax.
I tried a couple different modifications but nothing seems to be working.
Can you take a look at the code and screen shot attached.
the tree problem form elements do not have valid names.
You cannot use spaces when naming form elements, they are not allowed in form element names.
form elements must conform to the following naming rules:
1) Only alpha numeric characters are allowed, the only exception is the underscore "_"
2) The first character in the name must be a letter
"Phone Number" is not a valid name, but "PhoneNumber" or "Phone_Number" would be acceptable.
turk361661
Thank you!
you're welcome.
