PG Help doc oversight or not?
Thread begun 3/29/2011 2:52 am by Paul | Last modified 3/29/2011 10:53 am by Jason Byrnes | 2433 views | 3 replies |
PaulBeta Tester
I followed what was a text book installation, unpack, rename and upload...however,
The supporting installation instructions advise changing the installed folder to another name and when done, CS5 asks if the files it affects require updating accordingly. When this is accepted, CS5 will list all affected files and updates them.
However, I have noticed that for example, the file paths in pg/galleries/global.php do not change.
So in this example, the line;
defaults to require_once('Connections/powergallery.php');
My folder structure requires that it points to...
require_once('../../Connections/powergallery.php');
Also;
In the file pg/admin_gallery/index.php
The line "require_once('../../rename_and_upload_this_folder/admin_gallery/global.php');"
Clearly has not updated either. How many other instances of this are likely to exist and how do i know where to look?
And;
In the file pg/admin_gallery/global.php
//need to run installation wizard
if(!file_exists('../Connections/installed_gallery.txt')) {
    header('Location: ../install_gallery/index.php');
    exit();
} else {
    $installdate = realpath("../Connections/installed_gallery.txt");
    $handle = fopen($installdate, "r");
    $contents = fread($handle, filesize($installdate));
    if (strpos($contents,"\n")) $contents = substr($contents,strpos($contents,"\n"));
    fclose($handle);
require_once("../../rename_and_upload_this_folder/webassist/framework/library.php");
Features the same problem as above with renaming and incorrect file paths and also I do not have the file installed_gallery.txt present in this directory
Unless i'm missing something, there's nothing in the supporting docs to describe these instances and how to resolve them.
I assume this is affecting every file with lines referring to a path, so how do I ensure every path in every file affected by this issue is pointing to the correct path?
For a $99 dollar product, your quoting of a "painless setup" is a little dissapointing don't you think, when there seems to be so many tweaks required.
Thanks, Paul.
when CS5 asks you if you want to change the paths, you should decline.
the paths do not need to be changed.
If you are changing the folder name within Dreamweaver, when prompted to update paths, you should decline.
PaulBeta Tester
I have now managed to resolve this issue.
The setup documents were useful to a point but I have to say the gaps missed key steps and important detail.
If there are issues you have with the documentation, please post your concerns directly to the documentation team using the feedback form:
feedback.php?type=docs
