PG Help doc oversight or not?
Thread began 3/29/2011 2:41 am by Paul | Last modified 3/29/2011 10:48 am by Paul | 946 views | 2 replies |
PaulBeta Tester
I have noticed the file 'pg/galleries/global.php' contains the following line.
require_once('Connections/powergallery.php');
However, the file powergallery.php does not exist and the supporting docs do not explain what if anything the next steps should be.
Could you confirm if it does require modifying and to what?
Also can you get documentation updated with this step please.
Thank you, Paul.
the Connections/powergallery.php file is created when you run the installation wizard.
it is created based on the connection information you enter while running the install script.
you do not need to change that line.
If the Connections folder does not exist, it will run the install script and the install script will create it.
PaulBeta Tester
I have now resolved this issue.
