Cannot update CSS Menu 2.0.2
Thread begun 3/28/2011 9:30 pm by andre350765 | Last modified 4/27/2011 1:08 pm by Jason Byrnes | 1868 views | 3 replies |
andre350765
Once a menu is placed on the website, there is no way to update the menu if you need to add an extra page or add a drop down menu to one of the buttons.
The only way I have found to do this is to delete the menu and start over again.
Clicking on the menu does not bring up any options to edit, instead of deleting the menu I mainly just use code view to update.
Could you please tell if there is a way to edit the menu by bring up the CSS Menu panel to edit.
I'm using Dreamweaver CS5 version 11.0 Build 4964, and CSS Menu 2.0.2 on a iMac with Snow leopard.
If it is an HTML Menu, go to Edit -> Preferences. In the Invisible elements section, enable the Scripts invisible element.
then go to View -> Visual Aids and make sure the Invisible Elements section is checked.
Next to the menu you should see a script Icon, click the script icon to trigger the menu edit options in the properties panel, if the properties panel is not open, go to Windows -> Properties to open it.
mac193488
unable to edit CSS Menu writer
I have followed the steps indicated and cannot get the Writer editor to appear.
using a Mac Pro, Leapord, CS4
Also want to know if it is possible to have three different looks in the same menu
Look forward to hearing from you soon
