marker graphics very small
Thread begun 3/28/2011 8:45 am by asnw0764437428 | Last modified 3/28/2011 10:34 am by Jason Byrnes | 2167 views | 3 replies |
asnw0764437428
I have re-designed the marker graphics that show for each item pulled from a db on to the map. Problem is the marker graphics are displaying extremely small.
I have emptied the cache in both browsers and even re-applied the pro maps to the page, but still show up very small regardless of what zoom level you go in at. I have also set the option to have the details bubble for each item not to display, by selecting the driving directions option as discussed in another solution.
I have attached a grab of the map that shows the markers and also what the original marker looks like.
please send a link where i can see the problem to look into what may be causing it.
asnw0764437428
It would take too long to set up as its currently running on a testing server in-house. I have fixed the problem however.
I decided to set everything back to its initial state (default), found the lines of code within the wagmp_map_1 file that relate to the marker images and more importantly their image dimensions and altered things that way. It now works a treat, thanks.
Can I also suggest that in a further upgrade to the extension, that some of these features such as alternate image markers, default start zoom could be implemented in the initial settings panel? I am having to remember changes within a file that can be easily forgotten, if you don't use it that often or remember to make notes etc.
Also is there a way to alter the bubble graphic. Rather than rounded edges, have traditional square edges etc. etc.
Many thanks
Glad to hear you have it working.
Please post any requests for additional features to the wishlist forum.
