iepngfix.htc
Thread begun 6/29/2009 5:57 am by webmaster359615 | Last modified 8/27/2009 1:11 am by khubab1387847 | 6316 views | 3 replies |
webmaster359615
iepngfix.htc
I was wondering if anyone has had experience with this:
I have two related websites with nearly identical CSS Sculptor layouts except they use different colors and one is PHP and the other is mainly HTML. Both used iepngfix.htc (v2.0) to make the faux columns work in IE6.
The fix worked for the PHP site but not for the HTML site. Then I uploaded version 1.0 of the iepngfix.htc file, and it worked.
Any ideas?
Thank you.
Do you have a sample url? It is possible it is some sort of bug in the iepngfix.htc file if what you describe is true there wouldn't be many other explanations, so the real question would be what is it about your page that exposes that bug or issue and for that I would need to view the page.
webmaster359615
The URLs are below. The first is the problem. I had to use v1 of iepngfix.htc to make it work--but I reference v2 on the Home page, so you can see.
She second is almost a twin, but it works fine with v2.
www.peacockdata.com/
www.peacockdata2.com/
khubab1387847
You can find 100% working and tested iepngfix at www.nobleatom.com
