default bubble
Hello.
I have dynamic markers, the map always display a bubble after all the markers loaded.
How to set the default bubble ?
How to make no default bubble pop-up ?
Thanks.
Hello.
Thanks.
The default bubble is set as the last address in your recordset.
To set a specific address to be the default, you would need to set an order by clause on the recordset that would cause that address to be the last one.
the simplest way to cause the address bubble not to show on page load is to check the driving direction option, but do not enter a starting address.
