str_replace names in code
Thread begun 3/23/2011 12:45 pm by tone397472 | Last modified 4/12/2011 6:12 am by tone397472 | 5055 views | 7 replies |
tone397472
I received the code to change one name in the Blank.php email:
<?php echo(str_replace( "naam2", "naam", str_replace...etc.
But how do I change 5 different names? Can you please show me the code for that?!
Thanks a lot! David
can you give a little more detail on what you are trying to change?
are you trying to change the way the labels show in the email? taken from the form element names?
tone397472
Hi Jason,
Because I used a second instance of Universal Email on one web page I have to change some input names from a form. For example name2 in name.
The code I have in Blank.php works, but is only for one name.
<?php echo(str_replace( "name2", "name", str_replace... etc. How do I add more items to this line of code to replace?!
Thanks David
it's tough for me to tell exactly what you are doing here because you are not giving me the whole code block, the truncated code does not help.
I'm assuming you are doing the str_replace on the $pkey variable?
you can do more than one str_replace operation on the same variable, here is example code that would change a form element name "naam2" to "name" and another named "naamlast" to "last name"
echo(str_replace("naam2","name",str_replace("naamlast","last name",$pkey)));
for more details see the str_replace manual page on the php sire:
function.str-replace.php
tone397472
Thanks Jason! I'm going to try it!
David
you're welcome.
tone397472
Hi, The code works perfect to replace 2 items now, but I cant find out how to at more. I need to replace 5 items.
Can you please give me a example with more then 2.
what I have now:
Thanks David
tone397472
Sorry it was a typo! Missed a ) .
Thanks David
