Field Set won't delete
Thread begun 3/23/2011 11:14 am by roby258376 | Last modified 3/29/2011 8:14 am by Jason Byrnes | 3608 views | 10 replies |
roby258376
Hi there,
I have edited a form and I removed a fieldset from it. The fieldset no longer shows up in the list of fieldsets when I edit form contents but the header and it's box are still showing on my form.
Any suggestions?
can you send a link where i can see this problem please.
roby258376
ladies_golf_2.php
You'll see Player 1 listed as a title just below "I'd like to purchase..." and above "Total"
When I edit the form, this field doesn't show at all in the edit form contents window as seen in the attached screenshot.
to remove it from the page, delete the following code:
<li>
<fieldset class="HaltonTraumaCentre_TournamentofHope" id="Player_1">
<legend class="groupHeader">Player 1</legend>
<ul class="formList">
<li class="formItem"></li>
</ul>
</fieldset>
</li>
I think it may be left behind as a result of the other field set titled Player 1 on the page.
roby258376
Yes, I did that as a quick fix, but how do I get it removed from the form? I reuse this form so it would be great if I can fix it permanently.
Oh and it was left behind before I added a new Player 1 field to replace it. It was originally titled "Meal Preferences" and in an effort to get rid of it, I changed the order of the fields on the page, trying to get it to show up. Instead of showing up, it changed to Player 1. It's like my form has gremlins!
Any suggestion?
can you send a copy of the form preset.
go to the preset manager (insert -> Webassist -> Preset Manager) to export the preset.
roby258376
I do not appear to have a preset manager in that location - NM found it
roby258376
Here you go...
the file you have sent is the design preset.
I need the content Preset.
In the preset manager, select CSS Form Builder - Form Contents from the product list, and export the form contents preset.
roby258376
oops, sorry about that, I think this is the one you wanted...
