SSL Cert. Now what?
Thread begun 6/29/2009 4:37 am by lee365928 | Last modified 6/30/2009 1:40 am by lee365928 | 2358 views | 2 replies |
lee365928
SSL Cert. Now what?
I've created my site and finished the "getting started" tutorial. I've also just received my ssl certificate from my host. What do I do now to make sure the checkout goes to the https page of my site? My domains are as follows www.mydomain.com and www.mydomain.com. I've read the "assign ssl" tutorial and it says as long as my domains are the same (http and https) then I don't need the tutorial.
I've tried selecting the checkout button on my cart page and changing the server behavior from checkout.php to checkout.php, but that didn't work.
"I've tried selecting the checkout button on my cart page and changing the server behavior from checkout.php to checkout.php, but that didn't work."
That should work... are you sure you uploaded your page? What happens when it "doesn't work" it just ignores your update... try switching focus to another field before hitting OK when updating the checkout server behavior... maybe it isn't keeping your update because it really should work.
lee365928
That worked
Yes, it was always ignoring the update. Selecting another field before I saved did the trick. Thanks again.
