Cannot Login After Forgot Password Emails Random Password
Thread begun 3/22/2011 5:19 pm by dlovas275157 | Last modified 8/05/2011 11:11 am by un33k9309513 | 7521 views | 10 replies |
dlovas275157
I am having trouble being able to login after I have submitted the "forgot password form". I Have followed the SA Tutorial swf here exactly ( 07_send_password.swf ) and fully taken into consideration sha1 encryption.
Problem occurs when a the user tries to use the new random password (that is emailed to them) to login. It rejects everytime. Eventhough it is stored in the database as encrypted and the login page submits it encrypted.
I have verified that it is writing to the database in encrypted format, so I do not think this is the issue.
I have attached my code for the following pages since I am not sure on which page may be causing the issue:
1. login page
2. forgot password page
3. rejected page.
Help is much appreciated.
Thanks.
Using
Security Assist 1.1.9
Data Assist 2.0.7
in the update record behavior, you are storing an encrypted random string, using the random password generator and encrypting it.
you should be storing the encrypted version of the SV_newPassword session variable.
in the update record behavior, bind the password column to the SV_newPassword session variable and set the formation to use encryption.
dlovas275157
Jason,
Thank you ... that worked!
you're welcome.
un33k9309513
I have the same problem, where it sends the SHA1 password to the email and puts the SHA1 in the password field in the db.
I've been up reading posts and redoing this several times, but still sends the SHA1 to both email address and db, and the user can't log, he should be getting only 7 char. in his email.
thanks for your help
Ed
In the forgot password server behavior, on the last step, you can you define the email message that is sent.
remove the [password] token, then click the plus button and select the NewPW session variable.
un33k9309513
I did that and as soon as I clicked Finished, it put a red exclamation next to update record server behavior. So then I tested my file online and put my email in the forgot email section and the browser returned this message and there was no email sent:
Incorrect table name ''
Should I just install SA2 ? If I do I'm worried it may ruin my already made pages with SA. I have a registration page with multiple insert record behaviors. Can I install SA2 and just do the above stuff I'm trying to do? Can I also use crypt even though I have SHA1 using the old SA? I just don't want to create a massive problem. If I know installing the new SA2 won't conflict much with my old SA1 files I really want to upgrade, any suggestions Jason?
Thanks,
Ed
those 2 code snippets are identical.
please send a copy of the page i n zip archive rather than pasting the code.
un33k9309513
This post has been deleted.
