Insert with DataAssist 2.08
Thread begun 3/21/2011 6:33 pm by tom313187 | Last modified 3/25/2011 7:01 am by Jason Byrnes | 3945 views | 6 replies |
tom313187
I have updated the latest library file in all listed locations specified in the update. The standard generated insert page does not function properly on submit as the browser indicates it cannot load the page. No insert has been posted to the database. I have confirmed the most current library file is posted to the testing server.
can you send a copy of your insert page in a zip archive please.
tom313187
Zipped Standard Insert file
The only variation would be the re-direct to customer results instead of customer detail. In addition, I noticed that the URL was not a relative reference on the re-direct. This would be the issue. This issue would be within your standard code.
is it just the redirect that is not working?
I thought you also said the insert is not working?
I am sending a newer update to the library.php file that should correct the redirect issue.
let us know if there are still problems occurring, or if the insert itself is also an issue.
tom313187
New Library File
Jason thank you for the file. I have unzipped the file and updated the current library file in my directory. I then confirmed this update and PUT the file on my testing server. When I tested the new file the same error occurred. With the Safari browser I am able to confirm that the re-direct is looking for the file using the drive reference of the server and not a relative reference. In addition I have confirmed that no insert has taken place. No modification has been made to the file I submitted. I then re-confirmed that the new file was properly PUT to the server and my local development machine.
tom313187
Standard Insert
I also created a standard insert page using the server behaviors. The same error resulted. My intent was to test the wizard framework to see if it utilized the file in a different manner. The same result occurred, no insert and not URL re-direct. The library file was also placed within the helper folder in the CS5 sub directory as set forth in the technical notes provided with the original update.
