Problems with captcha graphic
Thread begun 3/20/2011 3:30 am by Paolo.Deluca422037 | Last modified 6/30/2011 7:35 am by Jason Byrnes | 3928 views | 7 replies |
Paolo.Deluca422037
Hi
I have tried to use the captcha option for a while on my online forms but with no success. I cannot understand why I dont see the images. I am running it on a Mac OSX 10.6 server and the GD libraries are enables
See this link as an example
captcha.php
Many thanks
Paolo
to troubleshoot, add the following code at line 1 of the webassist/captcha/wavt_captchasecurityimages.php file:
error_reporting
(E_ALL);
Paolo.Deluca422037
php code
Hi done the suggested changes and uploaded the file... but cannot see anything happening
gzirfas374932
No captcha images
I am having the same problem. No captcha images. I added the error reporting php code at line one of the aforementioned file and it doesn't report any errors. All of my other captcha files have worked, this one does not. Yes, I did upload the webassist folder to the server as always.
requestCAPTCHA.php
going directly to the captcha image file does show that there is an error:
monofont.ttf&textcolor=000000
usually the problem is either the GD library ot being enabled ot the True Type Library not being enabled. Double check with the host that those two are enabled on the server.
gzirfas374932
GD support was enabled no images
GD support was enabled version bundled (2.0.34 compatible) any other suggestions?
phpinfo.php
Don't know how to determine the true type library.
