Foreign Language products
Thread begun 3/19/2011 1:11 pm by bjgarner241692 | Last modified 3/22/2011 7:21 am by Jason Byrnes | 2145 views | 3 replies |
bjgarner241692
I have products in my shopping cart with foreign language names such as:
El Coma Elite - El Modo Elite para Prender al Bebé al Seno: ¡Ofrezca, Afiance, Transfiera!
or
Hojas de Información - Español
When the script encounters a special character, it breaks and I get errors such as this:
Warning: Missing argument 4 for eCart1_ItemDefinition::eCart1_ItemDefinition(), called in C:\path\2011\WA_eCart\WA_eCart_Definition_PHP.php(477) : eval()'d code on line 1 and defined in C:\path\2011\WA_eCart\eCart1_PHP.php on line 267
Can I change the language set of the eCart files to allow this to work? Some of the product may even be in Chinese or Russian so the character set will always be an issue.
in the eCart add to cart code for the product name binding, you can try using the php htmlentites() function to convert the special characters to HTML entities.
for example the code for the name binding may look like:
$ATC_itemName = "".$row_WADAProducts['ProductName']  ."";// column binding
change this to:
$ATC_itemName = "".htmlentities($row_WADAProducts['ProductName'],ENT_QUOTES,"UTF-8")  ."";// column binding
you may need to experiment with the character set being used. see the following page for details:
function.htmlentities.php
bjgarner241692
Brilliant!
Thanks!
you're welcome.
