PS3 Shop users can access the admin area!!
Is it true that the regular shop user accounts in power store 3 can also access the admin area if they put /Admin at the end of the root url or am I the only one who has this problem?
Regards.
Regards.
No, regular shop users cannot access the admin pages
If you have logged in as the Admin, then login as a regular shop user, this does not override your admin login so you will be able to access the admin area.
make sure in your testing that if you login in as the admin user that you logout before testing the actions of a regular user.
Jason,
I closed all open IE sessions. Surfed the the shop front end and logged in as a customer.
After that i just put /Admin behind the root and yes....I'm in the admin area.
I can see in the user list that this account has not the admin rights.
