Region map
Thread begun 3/17/2011 10:41 am by huijiun423574 | Last modified 3/17/2011 11:31 am by Jason Byrnes | 1422 views | 1 replies |
huijiun423574
Region map
Hello,
How to let map to display only a region between 2 points (34.13196, -116.040542) and (41.14914, -122.3093761)
Thanks.
not sure i totally understand your question.
the map will center on the coordinates you enter.
if you want the map to show a specific region, set the coordinates of the map to the center of the region you wish to display.
or you could use just the country, for example, if i enter just US into the address, the map i get back will be centered on the US.
or if I use CA in the state field, the map will be centered on the state of California.
