Setting PS 4.5
Thread begun 3/17/2011 7:51 am by Endrio | Last modified 3/22/2011 12:09 pm by Jason Byrnes | 5425 views | 9 replies |
Endrio
Setting PS 4.5
I have made update from PS 4,1 to PS 4,5, seems to work all unless when I want to change setting of the site I have this message:
Framwork rows not found:. /webassist/plugins/loader/loader.php
I hope that can be fixed as soon as possible.
Best
Endrio
It sounds like you did not copy the install/webassist folder over the webassist folder at the root of the site.
the steps fro updating are to:
1) Copy all of the php files and folders in the Power Store zip file and paste them over the files and folders on your site
2) Copy the install/webassist folder and paste it over the webassist folder at the root of your site
3) run the sql script that matches your update path in the install/scripts folder.
Endrio
I have made as you have advised to me, but does not work. you can control personally. here below the credentials to check the situation:
upload the attached file to webassist/plugins/loader/loader.php
Endrio
Hi Jason,
now I have this message:
Table 'Sql324276_5.ps4_countries' doesn't exist
and other error is when I want to edit a content I get this:
Warning: require_once(../webassist/ckeditor/ckeditor.php) [function.require-once]: failed to open stream: No such file or directory in /web/htdocs/www.rasoulinia.eu/home/admin/contents_update.php on line 5
Fatal error: require_once() [function.require]: Failed opening required '../webassist/ckeditor/ckeditor.php' (include_path='.:/php5/lib/php/') in /web/htdocs/www.rasoulinia.eu/home/admin/contents_update.php on line 5
Thanx
you have not followed the update instructions correctly, specificly:
make sure to upload the entire install/webassist folder to you site at the root of the power store files.
put another way:
if your site is uploaded to:
store
there will be a webassist folder at:
webassist
you need to overwrite this folder with the one in the install directory of the power store 4.5 zip file.
also in the install/scripts file, run the sql script for your update path on the database, this will create the ps4_countries table.
Endrio
Hi Jason,
I have made as you have advised to me it seems to work, but still have some problems.
1) the currency remains set up on US dollars.
2) when I edit a content I receive this message:
alert("MDB2 Error: no such table\nSELECT extension, plugin FROM kfm_plugin_extensions WHERE user_id=1")
3) when I modify in manage design a theme, it´s not changing it´s erasing
the last question is: if I install PS4.5 from zero with a new database, will it work?
Please test it by yourself:
Best
Endrio
donegan
Installing 4.5
I downloaded this load zip file after I had the same problem outlined above.
The Load problem has disappeared however, the problems I am now
having are the following problems:
1. Cannot update the settings in admin and save them, but I can see them now.
2. The settings in the shopping cart for shipping do not show up in the store
3. Shipping charges do not appear in a cart
3. In the "Design" can not see the pictures of the different layouts or edit them.
4. Product images do not show up in store.
You can see the problem I am having by going to the following link:
index.php
