multi seperate dropdowns in one form
Thread begun 3/16/2011 12:23 pm by Darren | Last modified 3/16/2011 1:34 pm by Darren | 1735 views | 4 replies |
Darren
setting up dropdown from A to B is fine but I also want another option on the form to have a seperate dropdown C to D. every time I set the second dropdown wizard it overwrites the first one.?
PHP Form
bike make - Trek (dropdown A)
bike model - carbon (dropdown B)
location - uk (dropdown C)
city - london (dropdown D)
any suggestions ?
you should have a separate recordset for each populate list from array behavior you apply to the page.
I have not had a problem in the past adding mutliple Populate list from array behaviors as long as there is a separate recordset for each one.
Darren
good news its possible, I wasn't sure - every time I run the wizard it shows the current setup so if I change this it overwrites it. maybe it depends what is selected at the time. tried with form selected, with new field selected..?
are you editing the current one, or adding a new one, it sounds like you are editing instead of adding a new one.
to add a new populate list from array behavior go to insert -> WebAssist -> Dynamic DropDowns -> Create dynamic Array
Darren
this is what I am doing creating a new one which is showing the current setup. I'll create a blank and post it
