Problems with checkout! HELP!
Thread begun 3/16/2011 10:42 am by scott351953 | Last modified 3/22/2011 7:05 am by Jason Byrnes | 6406 views | 12 replies |
scott351953
We just moved our store over to Powerstore and are experiencing a few issues with checkout page (where there personal and payment info is input).
1.) When the user enters their information and clicks submit, the form just sits there if they forget to enter a field (or get it incorrect). I realize it turns the field red as you are filling it out... but this seems tricky for some users. Any way to add a pop up? Or bring the user up to the incorrect field using an anchor link?
2.) The client wants to add some text next to the CSV field (under the text field), what file is this in? One of the plugin folders?
I guess these are not big issues, but it would be great if we can change these things.
Thanks in advance!
Scott
1) on the webassist/plugins/shoping_cart/checkout_form.php page, you could add the following at the top of the form to show an error:
if (ValidatedField("confirm","confirm"))  {
    if ((
strpos((",".ValidatedField("confirm","confirm").","), "," "" ",") !== false || "" == ""))  {
        if (!(
false))  {
            There are errors in the form submission
                    <?php //WAFV_Conditional confirm.php confirm(:)
2) the csv field is on that same page:
scott351953
Thank you! I will give that a try!
scott351953
Followup
1) I added the code in the head section and right above the form... It dose bring the user up... but not to the first wrong field (mine stops at the phone field). Any thoughts?
checkout.php
2.) Worked great! Must have missed this one.
Another question...
The ordering for the side menu and products is a little challenging because there is not control for this...
Whats the easiest way to order the side menu (Main and Sub categories)?
Whats the best way to order the products results?
Maybe add an order field to the table somewhere (I looked at the table and I am a little lost). If anyone has any ideas on how to do this it would be appreciated.
scott351953
On the order side bar menu... I read a post that explained changing the Order By to CategoryID. I tried this and it does not seem to work? If there is an easier way, please let me know.
PS - Here is the code: (sidemenu.php)
function getCatAccordion($StartWith=0,$prevLevels=0) {
$retHTML = "";
$retScript = "";
mysql_select_db($GLOBALS['database_PowerStoreConnection'], $GLOBALS['PowerStoreConnection']);
$query_SubCategoryList = "SELECT * FROM ps4_categories WHERE CategoryParent = ".$StartWith . " ORDER BY CategoryID";
$SubCategoryList = mysql_query($query_SubCategoryList, $GLOBALS['PowerStoreConnection']) or die(mysql_error());
$totalRows_SubCategoryList = mysql_num_rows($SubCategoryList);
$row_SubCategoryList = mysql_fetch_assoc($SubCategoryList);
$first = ($StartWith==0 && $prevLevels==0);
$selected = -1;
if ($row_SubCategoryList) {
$retHTML .= '<div id="Accordion'.$row_SubCategoryList["CategoryID"].'" class="Accordion" tabindex="0">' . "\n";
$retScript .= 'var Accordion'.$row_SubCategoryList["CategoryID"].' = new Spry.Widget.Accordion("Accordion'.$row_SubCategoryList["CategoryID"].'", { useFixedPanelHeights: false, defaultPanel: [defalutPanel] });' . "\n";
$CatCount = 0;
while ($row_SubCategoryList) {
$suboptions = getCatAccordion($row_SubCategoryList["CategoryID"],(1 + $prevLevels));
$retScript .= $suboptions[1];
$retHTML .= ' <div class="AccordionPanel'.(($prevLevels==0)?" AccordionTop":"").'" >' . "\n";
$retHTML .= ' <div catcount="'.$CatCount.'" class="AccordionPanelTab' . (($first)?" AccordionPanelFirst":""). '" onclick="doHighlighlight(this);updateContant(\'products_results_xml.php?Search=1&ProductCategoryID[]='.$row_SubCategoryList["CategoryID"].'\')" style="padding-left:'.(10+($prevLevels*5)).'px;">'.$row_SubCategoryList["CategoryName"].'</div>' . "\n";
$linkTo = 'products_results.php?Search=1&ProductCategoryID[]='.$row_SubCategoryList["CategoryID"];
$viewingPage = (basename($_SERVER['PHP_SELF'])."?".$_SERVER['QUERY_STRING']);
if (strtolower($viewingPage) == strtolower($linkTo) || $suboptions[3] >= 0) {
$selected = $CatCount;
if ($suboptions[0]!="") {
$retHTML .= ' <div class="AccordionPanelContent" >' . "\n";
$retHTML .= $suboptions[0];
$retHTML .= ' </div>' . "\n";
$first = false;
$totalRows_SubCategoryList--;
$last = ($totalRows_SubCategoryList < 1);
$CatCount++;
$retHTML .= '</div>' . "\n";
$retScript = str_replace("[defalutPanel]",$selected,$retScript);
return array($retHTML,$retScript,$totalRows_SubCategoryList,$selected);
$Accordion = getCatAccordion();
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<head>
<link href="../../../SpryAssets/SpryAccordion.css" rel="stylesheet" type="text/css" />
<script src="../../../SpryAssets/SpryAccordion.js" type="text/javascript"></script>
<script type="text/javascript" src="sidemenu.js"></script>
<link rel="stylesheet" type="text/css" href="sidemenu.css">
</head>
<body>
<?php echo($Accordion[0]); ?>
echo($Accordion[1]);
</script>
</body>
</html>
1) The code i gave was not intended to go to the first wrong field, server validations does not support that. it was intended to show a warning at the top of the form.
2) there are 2 files that control the side menu:
webassist/plugins/side_menu/sidemenu.php
and
webassist/plugins/side_menu/nested_accordion/sidemenu.php
you will need to change the ORDER BY clause in both of them.
scott351953
I was able to get the menu to order properly! Too bad on the validation... it would be nice to add a popup though. Thanks for all your help... Great Product!
scott351953
New Issues
I would like to add an SSL certificate to the checkout page (). Is there an easy way to do this? Not sure where to edit the code.
Also, we want to add a few payment seals/badges to the sidebar. Same this with the code... Not sure where I can add this in. (simple html for adding the security seals for authorize.net and our SSL certificate.
Thanks,
Scott
add the following code at line 1 of any page you want to force SSL access on:
if (!isset($_SERVER['HTTPS']) || (isset($_SERVER['HTTPS']) && strtolower($_SERVER['HTTPS']) != 'on')) {
header("Location: https://".$_SERVER['HTTP_HOST'].$_SERVER['PHP_SELF']);
    die();
if you want the seals to appear bellow the side menu, add them to the webassist/plugins/side_menu/sidemenu.php page.
scott351953
SSL Problem
Added the code above:
checkout.php
I get this error:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/77/6890977/html/checkout.php:7) in /home/content/77/6890977/html/WA_SecurityAssist/Helper_PHP.php on line 5
