Defualt Value to Form Field
Thread begun 3/16/2011 10:33 am by gary917 | Last modified 3/23/2011 8:01 am by Jason Byrnes | 5171 views | 9 replies |
gary917
Hi; I am trying to add a default value to my form fields so that I do not have to use labels.
I was trying to use the following code
value="Your Name:" onfocus="if(this.value=='Your Name:'){this.value=''}" onblur="if(this.value==''){this.value='Your Name:'}"
by adding it to...
<input id="Full_Name" name="Full_Name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("index2","Full_Name"):"")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Full_Name_ServerError');"/>
I can not get both to function together.
Any help would be appreciated.
to set a default value, change:
<input id="Full_Name" name="Full_Name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("index2","Full_Name"):"Your Default Value Here")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Full_Name_ServerError');"/>
gary917
This does not seem to work.
The error checking quits functioning, as well the field does not remove the default value once the field has focus (the cursor is placed in the field).
For example this how I would like the input field to function...
<input type="text" value="Your Name:" onfocus="if(this.value=='Your Name:'){this.value=''}" onblur="if(this.value==''){this.value='Your Name:'}"/>
My original is as follows...
<input id="Full_Name" name="Full_Name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("form2","Full_Name"):"")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Full_Name_ServerError'), if(this.value==''){this.value='Your Full Name'};"/>
I have then changed the input field to this, but the field quits functioning....
<input id="Full_Name" name="Full_Name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("form2","Full_Name"):"Your Full Name")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Full_Name_ServerError'), if(this.value==''){this.value='Your Full Name'};"/>
the problem in the code:
is that you are using a comma between the on blur functions:
it shgould be a semi colon:
onblur="hideServerError('Full_Name_ServerError'); if(this.value==''){this.value='Your Full Name'};"
use:
<input id="Full_Name" name="Full_Name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("form2","Full_Name"):"")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Full_Name_ServerError'); if(this.value==''){this.value='Your Full Name'};" onfocus="if(this.value=='Your Name:'){this.value=''}" />
gary917
Thanks but I am still having a problem.
When I add a default value to the field the default value should disappear when the field has focus (cursor is in the field), allowing the user to type a value into the field without highlighting/deleting the default value. I am not sure what I am doing wrong.
<input id="Full_Name" name="Full_Name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("form2","Full_Name"):"Your Full Name")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Full_Name_ServerError'); if(this.value==''){this.value='Your Full Name'};" onfocus="if(this.value=='Your Name:'){this.value=''}" />
Thanks again for all your help.
use the code i provided in my last reply:
Edit/Delete Message
gary917
No default value
Using the code you provided I am not getting any default value in the field; the field is blank. If a user leaves the field after clicking into it then the value appears.
ok, then using this code:
change it ot:
<input id="Full_Name" name="Full_Name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("form2","Full_Name"):"Your Full Name:")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Full_Name_ServerError'); if(this.value==''){this.value='Your Full Name'};" onfocus="if(this.value=='Your Full Name:'){this.value=''}" />
gary917
Thanks for your help
Thanks again
you're welcome.
