Php code for inserting group checkbox data into the database
Thread began 3/16/2011 6:39 am by sandeep.kesarwani423749 | Last modified 11/25/2014 11:50 pm by Nico | 3936 views | 4 replies |
Can anyone plz tell me what php code should be used to insert checkbox group data into the database. I am trying to insert left or right value of placement field. the code is as follows,
<label>
<input type="radio" name="placement[]" value="L" id="placement" />
Left</label>
<br />
<label>
<input type="radio" name="placement[]" value="R" id="placement" />
Right</label>
and for inserting:
if (isset($_POST["placement"]))?implode(", ", $_POST["placement"]):"") {
$placement = array($_POST['placement']);
$placement1 = explode(",", $placement);
$qry = "INSERT INTO `member`.`test` (`userid`, `placement`)
VALUES ('$userid', '$placement1');";
$result = @mysql_query($qry);
Can you plz provide me with full code.
in the insert record behavior, select the column this data should be stored to, and use the following code:
<?php echo ((isset($_POST["placement"]))?implode(", "$_POST["placement"]):""); ?>
Nico
Put array data in seperate columns
This works when we save data in one column. How can I save each array value in separate columns.
I have a checkbox of four values (1,2,3,4). I want to save each selected checkbox in a different column and not all in one.
you would need to hand code a loop to loop through the array, and use an insert to inner teach array piece, this will take hand coding to accomplish.
Here is a very simplistic example that shows how to do this;
<?php require_once('Connections/localhost.php'); ?>
<?php require_once("webassist/database_management/wa_appbuilder_php.php"); ?>
//if statement to make sure the checkbox group has a value
if(isset($_POST["CheckboxGroup1"])) {
//foreach loop added to loop through checkbox array
foreach($_POST["CheckboxGroup1"] as $k => $v) {
// WA DataAssist Insert
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $localhost;
$WA_table = "options";
$WA_sessionName = "OptionID";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "OptionID";
$WA_fieldNamesStr = "OptionName";
// original biunding for the checkbox form element
//$WA_fieldValuesStr = "".((isset($_POST["CheckboxGroup1"]))?$_POST["CheckboxGroup1"]:"") ."";
// edited to use the $v variable created by the for each loop
$WA_fieldValuesStr = "".($v) ."";
$WA_columnTypesStr = "',none,''";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_connectionDB = $database_localhost;
@session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
} //end foreach
} // end if
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<form id="form1" name="form1" method="post" action="">
<p>
<label>
<input type="checkbox" name="CheckboxGroup1[]" value="Item 1" id="CheckboxGroup1_0" />
Item 1</label>
<br />
<label>
<input type="checkbox" name="CheckboxGroup1[]" value="Item 2" id="CheckboxGroup1_1" />
Item 2</label>
<br />
<br />
<label>
<input type="submit" name="button" id="button" value="Submit" />
</label>
<br />
</p>
</form>
</body>
</html>
if you need more assistance, were can help through a premiere support appointment:
http://www.webassist.com/premier_request.php
Nico
Thank you
Thank you for the code.
I accomplished it another way
Named my database columns for each answer like this
answer_1,answer_2,answer_3
My checkboxes have values 1,2,3 for each option.
So when I save the data in the database i add the checkbox value as a parameter to the column name that it will be saved and I get something like this.
$InsertQuery->bindColumn("answer_".$_POST['optionvalue'][0]."", "i", "".((isset($_POST['optionvalue'][0]))?$_POST['optionvalue'][0]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("answer_".$_POST['optionvalue'][1]."", "i", "".((isset($_POST['optionvalue'][1]))?$_POST['optionvalue'][1]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("answer_".$_POST['optionvalue'][2]."", "i", "".((isset($_POST['optionvalue'][2]))?$_POST['optionvalue'][2]:"") ."", "WA_DEFAULT");
My checkboxes are like this
<input type="checkbox" name="optionvalue[]" id="optionvalue_1" class="optionvalueclass" value="1">
a) first answer</dd>
<input type="checkbox" name="optionvalue[]" id="optionvalue_2" class="optionvalueclass" value="2">
b) second answer</dd>
<input type="checkbox" name="optionvalue[]" class="optionvalueclass" id="optionvalue_3" value="3">
c) third answer
So what it happens when I submit the form, the query adds the data depending on the values of the checkboxes user has checked
