javascript error when applying upate multiple records server behavior
Thread begun 3/15/2011 9:46 am by sandy170299 | Last modified 5/02/2011 8:54 am by Jason Byrnes | 6095 views | 9 replies |
sandy170299
When I try to apply the update multiple records server behavior, I receive the following error and then none of the form fields update:
While executing ApplyServerBehavior in WADA_MultiUpdate.htm, a JavaScript error occurred.
have you tried deleting the Dreamweaver Cache file from the users configuration folder:
sandy170299
Yes, that's what I usually do first when I get javascript errors. I'm still getting the same error even after restarting Dreamweaver.
can you send a copy of your page please.
sandy170299
Zip file attached.
Steve Skinner
I just tried using the Multi-record update for the first time and ran into this same error. The webassist forum was the obvious place to start looking for a solution for this. Please advise...
before adding the multiple record insert behavior to your page, you need to apply the data assist repeat selection behavior. This error will occur if you use a repeat region on the page instead.
Zafar Iqbal
Error while using Multiple update server behavior
Dear Sir/Madam:
I am receiving this error:
I have tried deleting the Dreamweaver Cache file from the users configuration folder, and even unstalled it and then reinstalled, but still does not work, please help me out.
Thanks.
