Insert record and email details
Thread begun 3/14/2011 10:51 am by Joe Lowery | Last modified 3/15/2011 8:27 am by Jason Byrnes | 4913 views | 9 replies |
Joe Lowery
I'm using the WA Insert Record server behavior in combination with Universal Email on a page. I redirect the page in the UE server behavior (which occurs later in the code than the insert sb) to the same page with a passed argument that triggers a JavaScript "thank you" pop-up.
The record is being inserted and the email sent, but the page displayed after these actions are completed is blank, even though the correct path is shown in the browser location bar.
Any ideas on what could be going wrong?
Thanks - Joe
when a page displays blank, it usually means a php error has occurred, but error reporting is turned off.
add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
Joe Lowery
Thanks for the reply, Jason.
There seems to be a conflict between the DataAssist sb and the UE sb. When I add in the error reporting code, and reload the page I get this error at the top:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /contactMail.php:5) in /contactMail.php on line 116
If I comment out the session_start function on line 116, I get the "blank" page with the following errors:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /contactMail.php:5) in /contactMail.php on line 72
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /contactMail.php:5) in /contactMail.php on line 167
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /contactMail.php:5) in /contactMail.php on line 167
Fatal error: Cannot redeclare wa_ab_getloopedfieldname() (previously declared in /WA_DataAssist/WA_AppBuilder_PHP.php:12) in /webassist/database_management/wa_appbuilder_php.php on line 19
What should I do?
Thanks - Joe
My guess is that when you pasted the error reporting code into the page, you left a blank space between code blocks.
see this post for details on the headers already sent error:
showthread.php?t=19285
can you send a copy of the contactMail.php file so i can examine the code.
Joe Lowery
No obvious spaces or gaps.
I've attached the source file as a zip.
Thanks again for taking a look - Joe
in the webassist/email/mailformatting_php.php file, comment out line 55:
change:
require_once("../database_management/wa_appbuilder_php.php");
//require_once("../database_management/wa_appbuilder_php.php");
Joe Lowery
Getting closer... now I get the error:
Table 'rougeContacts.email_log' doesn't exist
which indeed it doesn't. What's the structure for the expected table?
use this SQL script to create the table:
CREATE TABLE email_log (
EmailID int(11) NOT NULL auto_increment,
EmailTo varchar(250),
EmailFrom varchar(250),
EmailSubject varchar(250),
EmailBody text,
EmailHeader text,
EmailError text,
EmailStatus varchar(50),
EmailDate timestamp default CURRENT_TIMESTAMP,
PRIMARY KEY (EmailID)
Joe Lowery
Thanks, Jason - that did it. It's all working perfectly now!
Best - Joe
Awesome, glad to hear it's working.
