If cookie is found, page is not redirecting
Thread begun 3/11/2011 9:15 am by sandy170299 | Last modified 3/11/2011 12:04 pm by Jason Byrnes | 4394 views | 7 replies |
sandy170299
On index2.php, I am creating a cookie using the following code:
if ("" == "") {
setcookie("ipaddress", "".((isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"") ."", time()+(60*60*24*30), "/", "", 0);
On the main page, index.php, I have the following code:
<?php echo((isset($_COOKIE["ipaddress"]))?$_COOKIE["ipaddress"]:"") ?>
<?php // find the ip address cookie, if its set, redirect
if (isset($_cookie["ipaddress"])) {
// redirect
header ('Location: index2.php');
The problem is, it's not redirecting. I've output the cookie on the page, so I know it's there, but I can't figure out why it's not redirecting to index2.php once it's found?
Thanks!
the problem is that you have the echo before the header function which will cause the headers already sent error.
your if statement must be before any output on the page, if you try to call the header function after there has been any output to the page, it will fail.
see this post for more details on the headers already sent error:
showthread.php?p=92580#post92580
I know you are not reporting the headers already sent error, but the echo statement before the header function is causing it to occur, and that is the root of the problem.
sandy170299
I removed this line
from line 1, but it's still not redirecting. I also was not receiving the "headers already sent" message. There were no errors at all. I only added that statement after it wasn't redirecting - to make sure that it was actually capturing the IP address.
you may not have error reporting on to see the error message.
add the following at line 1:
error_reporting
(E_ALL);
to turn error reporting on.
To troubleshoot any further, i would need a copy of the page.
sandy170299
Sorry, Jason. I'm still not getting any errors at all. I will zip the two pages for you and attach them.
keep in mind that php is a case sensitive language.
there is no variable in php names;
$_cookie
to reference cookies, sessions, form post or URLS, you must use capitols:
$_COOKIE
your echo line had the correct case:
but your if statement does not:
it should be:
if (isset($_COOKIE["ipaddress"])) {
sandy170299
Bingo! That's what I get for getting used to ColdFusion! You can pretty much do anything with it and put anything anywhere it doesn't care :P Thank you, Jason :)
yeah, php is a bit more strict in terms of syntax, but i find it a lot more flexible than cold fusion.
