Dataassist Repeat Region
Thread began 3/09/2011 4:18 am by ijs174940 | Last modified 3/10/2011 7:11 am by ijs174940 | 1675 views | 2 replies |
ijs174940Beta Tester
As I have seen in this forum there appears to be a lot of confusion over combining these two extensions, I would image that a possible future release would combine both these extensions so we could have the editablitiy of the form builder 2 with the data management of dataassist but in the meantime.
I would like to know how it is possible to add a css builder made form into the repeat region for the multiple insert dataassist behaviour.
you would need to add the data assist repeat region and multiple record insert behaviors to the form after it is created using form builder.
Yes I understand that but as there are lots of nested divs in the created form it makes it very difficult to isolate what area to select plus you cannot select the required code in the visual mode but in code view only.
