DataAssist Relationship Creation Fails
I've was just testing the Relationship option in DataAssist only to find the same bug still exists after all of the updates:
I created a rough mockup page just to test the feature prior to production of a new site.
Added everything in the usual fashion but everytime i get the same problem.
The Insert Page works, display the repeated child data as intended.
So in this case i create a record call product, select the colours I want and then hit insert
All saves fine until you add a new record. Repeat the process but it just over-writes the foreign key data rather than adding a new record.
File attached if you can pinpoint where the code is getting messed up i will know exactly where to look once i begin production of the new site and have to use this feature.
