Menu link - reload plugin only
Thread begun 3/08/2011 10:20 am by jshafor | Last modified 3/10/2011 9:25 am by Jason Byrnes | 1951 views | 3 replies |
jshafor
Good morning gentlemen,
I can't seem to make a function of Framework Builder work properly.
I have a page made up of plugins: the header; left column (menu); content; footer. The left column plugin (menu) is a spry accordion widget with other links that make up menu. The accordion default is set to load with all panels closed - and it all works fine (almost)! When I click on a specific link, it loads the category results in the content area like it should.
Since I didn't know a better (or other) way, I got the menu links (a href=) by running the search form, copying the "resulted" url:
(../index.php?S_ItemCat=6&Search.x=68&Search.y=6&Search=Search&page=itemsResults),
I changing the S_ItemCat=23 for the category I wanted to display. Again, that all works fine, however, as a consequence, when I click on the next menu item - it reloads the whole page - and you guessed it, the accordion goes back to it's default setting - which is all panels closed.
Therefore, I can't open the "Decor" panel, and click the "Auto" category, then click the "Office" category (and so on) without the page reloading and closing the "Decor" panel.
I'm stumped about how to reload the content area only - without loading the menu (left column plugin). I know it's because the ../index.php is included in the URL - but I can't seem to get anything else to work. . . please help. Thanks in advance!!
Here is the left column plugin code (obviously all the links aren't connected).
I included the index.php, leftColNav_inc.php, search.php, and results.php in the zip.
<a href="#">Apparel</a><br />
Cosmetics<br />
<div id="Accordion1" class="Accordion" tabindex="0">
<div class="AccordionPanel">
<div class="AccordionPanelTab">D&eacute;cor</div>
<div class="AccordionPanelContent">
<span class="menuItem"><a href="/Login/index.php">Auto</a></span><br />
<span class="menuItem">Home</span><br />
<span class="menuItem">Office</span>
</div>
</div>
Edibles<br />
<a href="../index.php?S_ItemCat=23&Search.x=68&Search.y=6&Search=Search&page=itemsResults">Fashion Accessories</a><br />
<div class="AccordionPanelTab">Glitter Tattoos</div>
<span class="menuItem">Glitter Tattoo Parties</span><br />
<span class="menuItem2"><a href="./?S_ItemCat=8&Search.x=68&Search.y=6&Search=Search&page=itemsResults">Photo Gallery</a></span><br />
<span class="menuItem2"><a href="../index.php?S_ItemCat=6&Search.x=68&Search.y=6&Search=Search&page=itemsResults">Pricing</a></span><br />
<span class="menuItem2">Request a Party</span><br />
<span class="menuItem">Tattoo Care</span><br />
<span class="menuItem">Testimonials</span><br />
<span class="menuItem2">Submit Testimonial</span><br />
</div>
</div>
Golf<br />
<div class="AccordionPanelTab">Jewelry</div>
<span class="menuItem">Bracelets</span><br />
<span class="menuItem">Earrigns</span><br />
<span class="menuItem">Necklaces</span><br />
<span class="menuItem">Pins</span><br />
<span class="menuItem">Rings</span>
</div>
</div>
</div>
Men's Collection<br />
Princess Collection<br />
Clearance<br />
make the main content area an iframe and give the iframe a name:
<iframe name="myIframe"></iframe>
then add target="myIframe" to your links
jshafor
Once again Jason - many thanks! I ultimately had to re-structure the page a bit; but works like a charm . . . I sincerely appreciate your help. And thanks for responding so quickly!!
Glad to hear it is working.
