update 3.0.0 - 3.0.1
Thread begun 3/07/2011 1:03 am by this_is_me | Last modified 3/08/2011 6:45 am by Jason Byrnes | 2565 views | 3 replies |
this_is_me
is there any steps necessary for updating 3.0.0 to 3.0.1?
I just created a site with version 3.0.0 and did some adjustments on the kfm/configuration.php to correct the paths. Now I updated to version 3.0.1 and don't see changes apart from this file. Do I need to upload some more files to the live server?
According to DA's description, corrections were:
* Updated for compatibility with CSS Form Builder, PowerCMS, and PowerStore.
* Added the ability to add styles from a selected style sheet.
* Corrected an issue that caused image paths for images inserted using an editor to be incorrect when the image location was outside of the editor's directory.
* Corrected an issue that caused an error to occur in Dreamweaver when updating a V2 advanced manager enabled editor.
* Corrected an issue that caused a File Manager to not create a sub-directory if one was specified during insert and the directory did not already exist.
* Corrected an issue that prevented Dreamweaver's Insert Record server behavior from recognizing a second HTML Editor instance on a page.
* Corrected an issue that caused eCart's Set Session Value server behavior to throw an error when being added to a page containing a stand-alone File Manager.
after uninstalling version 3.0 and installing version 3.1, you need to edit the HTML Instance on the page to have the code regenerated, then upload the webassist folder to the sever.
this_is_me
thank you
good hints.
Great extension, btw.
you're welcome.
