Caption info
Thread begun 3/02/2011 9:27 am by farnumfoto279323 | Last modified 3/03/2011 3:58 pm by Jason Byrnes | 4765 views | 9 replies |
farnumfoto279323
Caption info
I'm using the Grid+Lightbox Gallery. When I add a description I get <br/> in the copy any time I use a hard or soft return. How can I avoid this and still be able to properly lay out the text? Also, how can I get rid of the camera icon? I also noticed in the preview galleries that there is copy at the bottom of the larger expanded image, instead of just "Image 1 of 2". How can I apply that to my larger images? DO I need to add that text directly to the jpeg image itself? Thanks in advance.
to fix the br tag issue,
edit the mediarss.php file, change:
echo '<title>' . xmlencode($row['title']) . '</title><description>' . xmlencode(nl2br($row['description'])) . '</description><link></link>';
            echo '<media:title>' . xmlencode($row['title']) . '</media:title><media:description>' . xmlencode(nl2br($row['description'])) . '</media:description>';
echo '<title>' . xmlencode($row['title']) . '</title><description>' . xmlencode($row['description']) . '</description><link></link>';
            echo '<media:title>' . xmlencode($row['title']) . '</media:title><media:description>' . xmlencode($row['description']) . '</media:description>';
to remove the camera icon from the tooltip, edit the galleries/grid_lightbox/css/common.css file, change:
.pg-gl-tip .tip {
background-color: #fff;
padding: 7px;
background-image: url(../images/camera.png);
background-repeat: no-repeat;
background-position: 10px 10px;
.pg-gl-tip .tip {
padding: 7px;
//background-image: url(../images/camera.png);
I have attached an updated copy of the js/slimbox.js file to correct the problem with the file name not showing in the lisghtbox.
farnumfoto279323
br tag issue & removing camera icon
RE: br tag issue. I copy the code that you supplied, however, there was a problem with it. I thought I fixed the problem, but I still keep getting this error:
Parse error: syntax error, unexpected T_VARIABLE, expecting ',' or ';' in /hermes/web04/b185/as.douglasstephen/public_html/powergallery/mediarss.php on line 88
On line 88 I added a paren "(" before the $ - xmlencode$row['description']). After I did that there were no more "syntax error on line 88" messages, but I'm still getting the parse error when I try and preview the gallery. I'm also still seeing the camera even though I placed 2 forward slashes where you specified. Please advise. Thanks.
send a copy of the mediarss.php file and a link where i can see the problem.
farnumfoto279323
mediarss.php
Here's the link:
choosegallery.php
Here's the php file:
//make sure connections file exists
$rssdir = getcwd();
chdir(dirname(__FILE__));
require('Connections/powergallery.php');
require('webassist/framework/library.php');
chdir($rssdir);
mysql_select_db($database_powergallery);
if(empty($no_xml_header)) header('Content-type: text/xml');
$gallery_id = (isset($_GET['gallery']) && is_numeric($_GET['gallery'])) ? intval($_GET['gallery']) : false;
$thumb_size = isset($_GET['thumb']) ? $_GET['thumb'] : '62c';
$full_size = isset($_GET['full']) ? $_GET['full'] : '782p';
$super_size = isset($_GET['super']) ? $_GET['super'] : false;
$url_prefix = '';
$absLink = dirname(__FILE__);
$assumedRoot = (empty($_GET['local'])?$virtualdir:"") . "/".(abs2rel($absLink,$site_root)). "/";
$assumedRoot = str_replace("//", "/", $assumedRoot);
$WAGLOBAL_Root_URL = ((isset($_SERVER['SERVER_PROTOCOL']) && strpos($_SERVER['SERVER_PROTOCOL'], 'HTTPS') !== false) ? 'https://' : 'http://') . $_SERVER['SERVER_NAME'] .( (isset($_SERVER['SERVER_PORT'])&& $_SERVER['SERVER_PORT'] != 80)?":".$_SERVER['SERVER_PORT']:"") . $assumedRoot;
//global settings
$wa_settings = array();
$result = mysql_query('SELECT * FROM wa_settings');
while($row = mysql_fetch_assoc($result)) {
$wa_settings[$row['name']] = $row['value'];
//get first gallery id if none specified
if(!$gallery_id) {
$gallery_id = mysql_result(mysql_query('
SELECT COALESCE(id, 0) AS id
FROM pg1_gallery
ORDER BY id ASC LIMIT 0, 1'), 0, 'id');
//get url prefix if not set to local
if(empty($_GET['local'])) {
$url_prefix = $WAGLOBAL_Root_URL;
//gallery prefix
$gallery_prefix = 'images/' . $gallery_id . '/';
$url_prefix .= $gallery_prefix;
$gallery_prefix = realpath(dirname(__FILE__)) . '/' . $gallery_prefix;
if(!function_exists('xmlencode')) {
function xmlencode($s) {
return htmlspecialchars($s);
$result_gallery = mysql_query('
SELECT *
FROM pg1_gallery
WHERE id = ' . $gallery_id);
if(mysql_num_rows($result_gallery) == 1) {
$row_gallery = mysql_fetch_assoc($result_gallery);
echo '<?xml version="1.0" encoding="utf-8" standalone="yes"?>';
echo '<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/" xmlns:atom="http://www.w3.org/2005/Atom">';
echo '<channel><title>' . xmlencode($row_gallery['title']) . '</title><link></link><description></description><generator>PowerGallery by WebAssist</generator>';
SELECT *
FROM pg1_gallery_images
WHERE gallery_id = ' . $gallery_id . "
ORDER BY display_order ASC");
if(mysql_num_rows($result) > 0) {
//get image info
$thumb_file = $row['file_prefix'] . '_' . $thumb_size . '.' . $row['file_ext'];
$thumb_imagesize = @getimagesize($gallery_prefix . $thumb_file);
$full_file = $row['file_prefix'] . '_' . $full_size . '.' . $row['file_ext'];
$full_imagesize = @getimagesize($gallery_prefix . $full_file);
if(!empty($super_size)) {
$super_size_file = $row['file_prefix'] . '_' . $super_size . '.' . $row['file_ext'];
$super_size_imagesize = @getimagesize($gallery_prefix . $super_size_file);
//create item
echo '<item>';
echo '<media:thumbnail url="' . $url_prefix . $thumb_file . '" type="' . $thumb_imagesize['mime'] . '" ' . $thumb_imagesize[3] . ' />';
echo '<media:content url="' . $url_prefix . $full_file . '" type="' . $full_imagesize['mime'] . '" ' . $full_imagesize[3] . ' />';
echo '<media:supersize url="' . $url_prefix . $super_size_file . '" type="' . $super_size_imagesize['mime'] . '" ' . $super_size_imagesize[3] . ' />';
echo '</item>';
echo '</channel>';å
echo '</rss>';
I dont see a problem with this code, it looks correct.
I would suspect that the edit is not being uploaded to the server properly by Dreamweaver, delete the file off the server then re upload.
Is it on the choose gallery file,that you are seeing the camera icon or the gallery itself?
can you post a link to the gallery please
farnumfoto279323
Power Gallery
I deleted mediarss.php from the server and uploaded. Now it's working.
Here's the link to the gallery, still seeing the camera icon. Thanks for your help.
index.php?gallery=2&theme=dark
when i view the css directly on your server:
common.css
the camera.png has not been commented in the css:
.pg-gl-tip .tip {
padding: 7px;
your edits to the css are being uploaded to the server.
farnumfoto279323
common.css
I had to delete the common.css file from the server and then upload it. Now the camera is gone.
Thanks.
glad to hear it is working.
