Creating Database Connection in DW CS4
Thread begun 6/28/2009 2:14 pm by toby379423 | Last modified 6/29/2009 6:58 pm by toby379423 | 4056 views | 3 replies |
toby379423
Hi there,
I've set up a database connection in Dreamweaver CS4 using the Databases panel, as shown in the "sp_db_connection" PDF, but here's my concern.
The database seems to be set up & working, but when I click "test" or 'select" I get "An unidentified error has occurred" message.
1 use 1&1.com for hosting & this is the info I have upon setting up a new database (which I've entered in the Databases Panel):
DB Name:
db290585078
User Name:
dbo290585078
Password:
XXXXXXXX
Host Name:
db1928.perfora.net
Description:
CanvasToArt
My only guess after doing a little research is that I need to put in the IP address in the Connection name field in DW. Right now I have localhost in there. Is this correct?
Justin Nemeth
If you setup your testing server in the DW site configuration, that should do the trick. Basically, DW needs access to the server so that it can verify and establish the database connection.
toby379423
OK,
I just set up a testing server & now I get an error message that says:
MySQL Error#: 2005
Unknown MySQL server host 'db290585078"(1)
toby379423
Figured it out! Thanks for the help!
