Alignment Issue
Thread begun 6/28/2009 1:03 pm by info355813 | Last modified 6/30/2009 2:01 pm by Justin Nemeth | 5953 views | 4 replies |
info355813
Alignment Issue
I am having a problem, probably pretty simple just don't know enough yet, getting a css menu to line up flush with a template I made. It hangs over about 10 or 20 pixels. I've tried to adjust stuff in css menu writer and site assist, and a few things by hand but no luck. Any ideas on what I need to do? Thanks for the help.
Justin Nemeth
If you provide a URL I can take a look. It's hard to guess what the issue could be.
info355813
Sorry about that: 2bar/
You can probably just adjust the margins to get it to line up:
ul#cssmw0 {menu.css (line 1)
cursor:default;
list-style-type:none;
margin-bottom:0;
margin-right:20px;
margin-top:-15px;
Justin Nemeth
looks like you can just add "padding-right: 10px" to the #topNavigation CSS and that will move the menu over. By default a div is going to be 100% width, so in the case of our layout, that was causing an overlap. The right padding will offset it a little bit.
