Filter data in select to omit records related to logged in user.
Thread begun 3/01/2011 9:57 am by troyd | Last modified 3/21/2011 7:45 am by Jason Byrnes | 6613 views | 16 replies |
troyd
I wasn't sure where to post this. I can add more details but figured I would start with the basics in hopes it was just something I wasn't grasping but might be an easy fix.
I have a page that people will log in to and then see a list of event dates. They will also see a form with 2 selects. A drop down select with the event date and a second with a number of tables to choose. This form inserts a record into a relational table. All of this is working.
Everything working but the date drop down. See, it's still showing a date that is already in the user's reserved list.
Here are two of my tables. (there's a third for users info.)
Parent event table
Child user to event table
Here's what I need. Since the dropdown is dynamically populated by a recordset, it needs to show only dates that the user has not already registered for. Basically the opposite of the other list that displays the events they DID register for. I need this list (drop down in form) to show the events they did not register for.
My attempts so far have given me partial results.
Here is my SQL for the list that shows their registrations.
SELECT users.UserID, date_format(show_date, '%M %e, %Y') as show_date, UserFirstName, UserLastName, reserved
FROM tblbooths LEFT JOIN tblreserved ON tblbooths.booth_id = tblreserved.booth_id
LEFT JOIN users ON users.UserID = tblreserved.UserID
WHERE tblreserved.UserID = ParamUserID
GROUP BY show_date
(with)
ParamUserID
integer
-1
$_SESSION['UserID']
How would I create the opposite that would show all event dates that the user has not already registered for? Seems simple I know. But using WHERE UserID != ParamUserID won't do it because there are records that do not have the user's id in it, but still have the date they already registered for. So I tried HAVING so it would do it after the grouping of dates. That partially works, but still leaves a couple dates in there for some reason.
SQL for the select that I have tried, but doesn't work.
SELECT capacity, date_format(show_date, '%M %e, %Y') as show_date, tblbooths.booth_id, COALESCE(sum(reserved), 0) AS total, UserID, capacity - COALESCE(sum(reserved), 0) AS available
WHERE show_date >= CURDATE()
GROUP BY show_date
HAVING UserID != ParamUserID
Ideally I would like just one recordset that worked for both areas. But that's not a big deal. On that note. Is there a way to bind the first recordset to both areas in php and maybe an if statement? I would alter it a little. Just a thought.
Thanks,
TroyD
did you try:
WHERE tblreserved.UserID != ParamUserID
If that doesn't work, I will need a sql dump og the tables to work directly with the data.
troyd
That didn't work.
What kind of sql dump where you referring to? Sorry, hadn't done that one yet.
TroyD
troyd
Sorry Jason. I no more than submitted that last reply and it dawned on me what you were needing. Hopefully this is right.
Thanks,
TroyD
i must be missing something.
lets assume where searching using UserID 5.
If i run the query:
FROM tblbooths inner JOIN tblreserved ON tblbooths.booth_id = tblreserved.booth_id
inner JOIN users ON users.UserID = tblreserved.UserID
WHERE tblreserved.UserID != 5
GROUP BY show_date
I get the results shown in the first screen shot. this seams correct to me based on your original description. Can you explain what you you are expecting to see differently? this will help me understand what you are after.
troyd
Sure, sorry if I wasn't explaining it right.
You see how the dropdown on my screenshot shows June 26?
The user as you can see in the bottom list already registered. So that June 26 date should not be there as a choice now.
What you can't see in the dropdown (because it's closed in the shot), is that August is also available. That one would be correct and is the only date that should be available to the user.
I looked at your screenshot. It shows a return of May1, June 26 and August 28.
The user as mentioned above should only be seeing August 28.
The query is doing what it's being told and filtering out the UserID = 5. But since userid 6 has registered for dates = to dates that userid 5 has, I need those gone too because I don't want userid 5 to re register for the same dates.
Sometimes things sound correct in my head but I am saying the wrong. I can try to explain this a different way if needed. Sorry for the rambling.
Basically what I need is a filter that says, remove all UserID = 5 AND also remove all other records which have a date = to any of the records with the UserID of 5. :)
Thanks,
TroyD
OK, now it makes sense.
This should do the trick:
SELECT users.UserID, show_date, UserFirstName, UserLastName, reserved
WHERE tblreserved.UserID != 5 AND tblreserved.booth_id NOT IN (SELECT booth_id FROM tblreserved WHERE UserID = 5)
troyd
Jason, your a genius!
Thanks so much. Works perfectly. And I can see by the way you wrote the sql, I was way off. But that's how I learn. Trust me, I will be dissecting this and learning from it.
I added in the ParamUserID and tested it on all of my fake user accounts. And as you would expect, it works as it should. This makes my day.
Again. Thanks,
TroyD
glad to hear it is working, I just needed a good explanation of why the results weren't correct to find where the problem was.
troyd
Jason,
I overlooked one detail. It still works, but only if there are several records in the tblreserved already. For testing (and in the sql dumb I sent you), I just happened to have each of the event dates reserved by someone. SO, if this is a fresh database and nobody has registered, or if some dates have not been registered, they are not included as a choice for anyone to register.
I tried for several hours to alter your sql before bugging you about it again. No luck.
My thoughts were that maybe I needed to include an "if" in the sql. So, if the UserID = ParamUserID or if the UserID != ParamUserID, then do all that. Otherwise include all the dates in the tblbooths table. But I couldn't get it to work.
Also, just a small added question. In your opinion, should my tblreserved table have a unique table id? Right now I have both booth_id and UserID as primary/unique together. But adding a WA delete or update behavior might not work.?
Thanks,
TroyD
