URGENT! Powergalleries Off Line
Thread began 3/01/2011 8:24 am by photoeyes2u348674 | Last modified 3/02/2011 12:52 pm by Jason Byrnes | 1491 views | 5 replies |
photoeyes2u348674
I have 3 powergalleries set up with one database. The following error message is one of the gallery messages I get when I click on the photo set up as a hyperlink to the gallery. I haven't changed anything so I don't know what has happened. I can't log into the admin area for these galleries either.
I set up other galleries with a different database and they work fine.
Warning: mysql_pconnect() [function.mysql-pconnect]: Access denied for user 'carscla2'@'localhost' (using password: YES) in /home/carscla2/public_html/Powergallery/Connections/powergallery.php on line 9
Fatal error: Access denied for user 'carscla2'@'localhost' (using password: YES) in /home/carscla2/public_html/Powergallery/Connections/powergallery.php on line 9
photoeyes2u348674
I just did the session test and the following is the result when I click #2 to test the session variables. It doesn't go back to the "test=test"
sessionTest.php
the error is saying that the either the database username or password you are using is not correct.
double check the username and password you are entering for the database connection to make sure it is correct for the server you are installing the gallery to.
If you perform the installation on one server, then copy the files to another server, it will not have the correct connection information in the connection file.
photoeyes2u348674
Thanks for the prompt reply. When I try to log into the admin area, I can't even do that. The admin page doesn't come up, so I can't put in the username or password. I did replace the "global.php" with the new one I found in a thread about that.
Now, I can't log into the new gallery "Background1" either; no admin log in page, but the 2 galleries I have for the database work fine online. Below is the error message when I try to log into this admin now. I have logged into my web host and checked the databases and they seem to be ok. I haven't changed any usernames or passwords.
"Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/carscla2/public_html/Background1/admin_gallery/global.php on line 37
Warning: Cannot modify header information - headers already sent by (output started at /home/carscla2/public_html/Background1/admin_gallery/global.php:37) in /home/carscla2/public_html/Background1/admin_gallery/index.php on line 6"
photoeyes2u348674
I've been doing some more checking on this. The database for powergallery (the one with the 3 galleries) has all the content online. However, it shows 0 mb for the size in My SQL Databases and there are no tables in the phpMyAdmin area for this one.
The other databases are fine and their usernames and passwords look ok.
