2 where clauses in data assist search
Thread begun 3/01/2011 4:22 am by mr hankey | Last modified 3/03/2011 8:33 am by Jason Byrnes | 1728 views | 3 replies |
mr hankey
hi,
i have tried adding in the wizard 2 where clauses as you will see from my code however it does not work. it is executing the first where clause but the second it is not. it shows the archived properties even though i want it to only show the non archived properties (= 0) (archive = 1)
here is the the php code:
<?php require_once('Connections/cbank.php'); ?>
// Load the tNG classes
require_once('includes/tng/tNG.inc.php');
// Make unified connection variable
$conn_cbank = new KT_connection($cbank, $database_cbank);
//Start Restrict Access To Page
$restrict = new tNG_RestrictAccess($conn_cbank, "");
//Grand Levels: Level
$restrict->addLevel("1");
$restrict->Execute();
//End Restrict Access To Page
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAproperties;
//Searchpage: properties_Results.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere = "ProductTypeID <= 14 and Archive = 0";
if ((isset($_GET["WADbSearch1"])) && ($_GET["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr1 = array("PropertyRef");
$KeyArr2 = array("SaleType");
$KeyArr3 = array("Country");
$KeyArr4 = array("Development");
$KeyArr5 = array("PropertyCompany");
//comparison list additions
$WADbSearch1->addComparisonFromEdit("PriceofProperty","S_PriceofProperty","AND","=",1);
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_GET["S_PropertyRef"]))?$_GET["S_PropertyRef"]:"") ."","OR","Includes",",%20","%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr2,"".((isset($_GET["S_SaleType"]))?$_GET["S_SaleType"]:"") ."","OR","Includes",",%20","%20","%22","%22",0);
$WADbSearch1->addComparisonFromEdit("ProductTypeID","S_ProductTypeID","OR","=",1);
$WADbSearch1->keywordComparison($KeyArr3,"".((isset($_GET["S_Country"]))?$_GET["S_Country"]:"") ."","OR","Includes",",%20","%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr4,"".((isset($_GET["S_Development"]))?$_GET["S_Development"]:"") ."","OR","Includes",",%20","%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr5,"".((isset($_GET["S_PropertyCompany"]))?$_GET["S_PropertyCompany"]:"") ."","OR","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_properties_Results"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_properties_Results"]) && $_SESSION["WADbSearch1_properties_Results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_properties_Results"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_WADAproperties = 10;
$pageNum_WADAproperties = 0;
if (isset($_GET['pageNum_WADAproperties'])) {
$pageNum_WADAproperties = $_GET['pageNum_WADAproperties'];
$startRow_WADAproperties = $pageNum_WADAproperties * $maxRows_WADAproperties;
mysql_select_db($database_cbank, $cbank);
$query_WADAproperties = "SELECT PropertyID, ProductTypeID, clients_ClientID, PropertyRef, SaleType, Country, PropertyCompany, Development, PropertyType, UnitNo, PriceofProperty, ProductName, ProductDescription, Scurrency, DepositPercentage, Special, SpecialPrice, DateSpecialEnds, GMAPCommission, APCommission, PCCommission, AgentCommission, SubAgentCommission, IFAFee, SippFee, Image1, Image1path, Image2, Image2Path, Archive FROM properties ORDER BY PriceofProperty ASC";
setQueryBuilderSource($query_WADAproperties,$WADbSearch1,false);
$query_limit_WADAproperties = sprintf("%s LIMIT %d, %d", $query_WADAproperties, $startRow_WADAproperties, $maxRows_WADAproperties);
$WADAproperties = mysql_query($query_limit_WADAproperties, $cbank) or die(mysql_error());
$row_WADAproperties = mysql_fetch_assoc($WADAproperties);
if (isset($_GET['totalRows_WADAproperties'])) {
$totalRows_WADAproperties = $_GET['totalRows_WADAproperties'];
} else {
$all_WADAproperties = mysql_query($query_WADAproperties);
$totalRows_WADAproperties = mysql_num_rows($all_WADAproperties);
$totalPages_WADAproperties = ceil($totalRows_WADAproperties/$maxRows_WADAproperties)-1;
$maxRows_WADADynListproduct_provider = 1000;
$pageNum_WADADynListproduct_provider = 0;
if (isset($_GET['pageNum_WADADynListproduct_provider'])) {
$pageNum_WADADynListproduct_provider = $_GET['pageNum_WADADynListproduct_provider'];
$startRow_WADADynListproduct_provider = $pageNum_WADADynListproduct_provider * $maxRows_WADADynListproduct_provider;
$query_WADADynListproduct_provider = "SELECT ProductProvider, ProductProvider FROM product_provider ORDER BY ProductProvider";
$query_limit_WADADynListproduct_provider = sprintf("%s LIMIT %d, %d", $query_WADADynListproduct_provider, $startRow_WADADynListproduct_provider, $maxRows_WADADynListproduct_provider);
$WADADynListproduct_provider = mysql_query($query_limit_WADADynListproduct_provider, $cbank) or die(mysql_error());
$row_WADADynListproduct_provider = mysql_fetch_assoc($WADADynListproduct_provider);
if (isset($_GET['totalRows_WADADynListproduct_provider'])) {
$totalRows_WADADynListproduct_provider = $_GET['totalRows_WADADynListproduct_provider'];
} else {
$all_WADADynListproduct_provider = mysql_query($query_WADADynListproduct_provider);
$totalRows_WADADynListproduct_provider = mysql_num_rows($all_WADADynListproduct_provider);
$totalPages_WADADynListproduct_provider = ceil($totalRows_WADADynListproduct_provider/$maxRows_WADADynListproduct_provider)-1;
$queryString_WADAproperties = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAproperties") == false &&
stristr($param, "totalRows_WADAproperties") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAproperties = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAproperties = sprintf("&totalRows_WADAproperties=%d%s", $totalRows_WADAproperties, $queryString_WADAproperties);
// Show Dynamic Thumbnail
$objDynamicThumb1 = new tNG_DynamicThumbnail("", "KT_thumbnail1");
$objDynamicThumb1->setFolder("PropImages/");
$objDynamicThumb1->setRenameRule("{WADAproperties.Image1}");
$objDynamicThumb1->setResize(250, 150, false);
$objDynamicThumb1->setWatermark(false);
$objDynamicThumb1->setPopupSize(800, 600, false);
$objDynamicThumb1->setPopupNavigation(true);
$objDynamicThumb1->setPopupWatermark(false);
$objDynamicThumb1->setRenameRule("{WADAproperties.Image1path}");
$objDynamicThumb1->setResize(250, 250, false);
$objDynamicThumb1->setPopupNavigation(false);
is there a way to have 2 where clauses using data assist?
thanks
instead of adding it to the defulat where clause, add it to the main recordset:
SELECT PropertyID, ProductTypeID, clients_ClientID, PropertyRef, SaleType, Country, PropertyCompany, Development, PropertyType, UnitNo, PriceofProperty, ProductName, ProductDescription, Scurrency, DepositPercentage, Special, SpecialPrice, DateSpecialEnds, GMAPCommission, APCommission, PCCommission, AgentCommission, SubAgentCommission, IFAFee, SippFee, Image1, Image1path, Image2, Image2Path, Archive FROM properties WHERE ProductTypeID <= 14 AND Archive = 0 ORDER BY PriceofProperty ASC
mr hankey
thansk jason, when changing it in the recordset this works in dreamweaver and displays the correct results however now the search function does not work.
here is code:
$WADbSearch1_DefaultWhere = "";
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$query_WADAproperties = "SELECT PropertyID, ProductTypeID, clients_ClientID, PropertyRef, SaleType, Country, PropertyCompany, Development, PropertyType, UnitNo, PriceofProperty, ProductName, ProductDescription, Scurrency, DepositPercentage, Special, SpecialPrice, DateSpecialEnds, GMAPCommission, APCommission, PCCommission, AgentCommission, SubAgentCommission, IFAFee, SippFee, Image1, Image1path, Image2, Image2Path, Archive FROM properties WHERE ProductTypeID <= 14 AND Archive = 0 ORDER BY PriceofProperty ASC";
} else {
} else {
to troubleshoot, add the following code after the <body> tag:
SQL: <?php echo($query_limit_WADAproperties); ?><br />
please send a link where i can see the problem.
instead of pasting the code in your message, please add the php page to a zip archive and attach the zip archive to your message so I can see the entire page code in context.
