Coupon - "Free Shipping" or "Free Item"
Thread begun 6/28/2009 12:06 pm by digitaldesign | Last modified 6/30/2009 7:09 am by digitaldesign | 2056 views | 2 replies |
digitaldesign
Question on how to make a dynamic discount code/coupon section that will let the buyer have a free widget with any purchase over $25. Another scenario may be a free yadget when buying item A and item B and it's before July 31.
It will need to be dynamic (PHP MySQL) from a "promotions" table.
Are these types of promotions too complex for the eCart system or can the discounts be applied dynamically?
Thanks!
Monica K
bjgarner241692
I can't give you the PHP code straight up but I've done this in ASP.
Create a table in your db with Coupon Codes and Values.
Insert a field on your checkout page for Coupon Code.
Create a discount in the eCart that applies only if the Coupon Code matches one in the db.
ie: if Coupon Code matches, then do Discount Calculation
digitaldesign
That sounds simple enough. Just a set of Boolean logic. I'll give it a go!
Thanks much!
