Delete files not deleting files on delete record action
Thread begun 2/27/2011 6:50 am by robert254422 | Last modified 7/25/2014 5:02 pm by bjgarner241692 | 9171 views | 15 replies |
robert254422
Hello ...,
Using universal email 4 - feature: delete files in combination with delete record (data-assist).
On inserting and updating records and files all works well but when it gets time to delete record and associated files only the record gets deleted the associated files remain on server...
// WA Application Builder Delete
if (isset($_POST["Delete_x"])) // Trigger
$WA_connection = $xxx;
$WA_table = "xxx";
$WA_redirectURL = "xxx.php";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "Cat_Id";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_site;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
$WA_DeleteFileResult1 = false;
if(isset($_POST["Delete_x"])){
$WA_DeleteFileResult1 = WA_FileAssist_DeleteFile("../Uploads/Catalogi/", "".((isset($_POST["Cat_Omslag"]))?$_POST["Cat_Omslag"]:"") ."");
$WA_DeleteFileResult2 = false;
$WA_DeleteFileResult2 = WA_FileAssist_DeleteFile("../Uploads/Catalogi/", "".((isset($_POST["Cat_Pdf"]))?$_POST["Cat_Pdf"]:"") ."");
$WA_DeleteFileResult3 = false;
$WA_DeleteFileResult3 = WA_FileAssist_DeleteFile("../Uploads/Catalogi/", "".((isset($_POST["Cat_Zip"]))?$_POST["Cat_Zip"]:"") ."");
$WA_DeleteFileResult4 = false;
$WA_DeleteFileResult4 = WA_FileAssist_DeleteFile("../Uploads/Catalogi/", "".((isset($_POST["Cat_Omslag2"]))?$_POST["Cat_Omslag2"]:"") ."");
$WA_DeleteFileResult5 = false;
$WA_DeleteFileResult5 = WA_FileAssist_DeleteFile("../Uploads/Catalogi/", "".((isset($_POST["Cat_Omslag3"]))?$_POST["Cat_Omslag3"]:"") ."");
$WA_DeleteFileResult6 = false;
$WA_DeleteFileResult6 = WA_FileAssist_DeleteFile("../Uploads/Catalogi/", "".((isset($_POST["Cat_Omslag4"]))?$_POST["Cat_Omslag4"]:"") ."");
I hope this is enough code to see what is going wrong or what I am doing wrong...
WKR
RV
The delete file code needs to be before the delete record code.
PHP is executed form top to bottom, currently you have the delete record being executed before the delete file code.
the delete record behavior is set to redirect to another page, the redirect is occurring before the delete file code has a change to execute.
move the delete file behaviors above the delete record behavior.
robert254422
That did it...
Sorry for the late response... To make the thread complete though... changing the order of the code did the trick...
TYVM!
bjgarner241692
I have the same issue. Delete File behaviours are before the delete record. Record deletes, but not files. Full page code is below.
the WADAs_applications recordset that you are using to return the file name and folder name is not filtered.
create another recordset to query the s_applications table, set this recordset to filter the aID on the WADADeleteRecordID form element, and use that recordset in the delete behaviors for the file and folder name settings.
bjgarner241692
Thanks. That seems to get me closer but no I am getting an unlink error. I know for certain that the permissions on the folder are correct so that leads me to believe that I am still pointing somehow to the wrong folder.
How can I see where the code is pointing?
ie: I want to do something like this:
<?php echo "../apps/".$row_deleterecord['lname']  ."""".$row_deleterecord['resume']  ."";?>
although that does not work, I am hoping you get the idea.
The error should have the path it is trying to look at.
or you could use:
<?php echo "../apps/".$row_deleterecord['lname'] ."/".$row_deleterecord['resume'] ."";?>
to write the path.
bjgarner241692
I cannot use the Form value, I suspect because nothing is being posted.
I created a recordset using the aID value from the main recordset as the parameter. I inserted the recordset within the repeat region and can successfully show the correct path and filename for each row. I can even link the associated files.
Still though, when I click delete, it deletes the record, but not the files.
regardless of weather you can write the file names to the page at page load, the values are not sent when the delete button is pressed.
only the WADADeleteRecordID for element is passed when the delete button is pressed.
so you need to use the secondary recordset like i suggested before, and use the secondary recordset i nthe delette behavior.
In the code you paste above, I don't see any delete file behaviors, nor do I see the secondary recordset.
bjgarner241692
Recordset is at line 439
Behaviour is at 131
You are correct, delete behaviour was missing. I copied the wrong file.
Zip is attached.
I have tried the same thing using WADADeleteRecordID but it did not work then either. I was using $POST['WADADeleteRecordID'] in the parameter.
