Display Manager!
Thread began 2/26/2011 6:47 pm by help_info383092 | Last modified 2/28/2011 7:13 am by Jason Byrnes | 1275 views | 1 replies |
help_info383092
Display Manager!
Do you have to create display manager, confirm, and checkout for each item? I have tried to put 2 items in the display manager and it only wokred for one item. I am creating a static shopping cart.
Regards,
Eric
No, the display manager is applied to the entire cart.
If only one item is showing in the cart display, make sure that you do not have multiple cart objects defined.
it could be that you have the add to cart button for the first item set to use one cart object and the second add to cart button set t use a different cart object.
If that's not the case, make sure that the ID's being used for each add to cart button are unique.
