Strange Syntax Error
Thread begun 2/26/2011 12:02 pm by anonymous | Last modified 2/28/2011 8:33 am by Jason Byrnes | 1861 views | 1 replies |
anonymous
I was using the dynamic plug in feature with many possible cases and keep getting a syntax error. The top of the switch case code starts like this:
switch(isset(((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:""))?((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:""):""){
I noticed, though, just by removing the first "isset" between the first and second parenthesis seems to fix the issue like this:
switch((((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:""))?((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:""):""){
I have been trying to figure out if that first "isset" check is really needed or is that a bug being generated?
Best regards,
Brian
I have logged this as a bug in our bugbase, the correct switch statement should be
switch(isset($_SERVER["SERVER_NAME"])?$_SERVER["SERVER_NAME"]:""){
