Splitting results into groups of 5
Thread begun 2/26/2011 7:58 am by phebberd116714 | Last modified 3/02/2011 6:39 am by Jason Byrnes | 5890 views | 13 replies |
phebberd116714
I would like to display the results of a record set in groups of 5.
Each group would be in a div container and each item in an unordered list.
Like this:
<div>
<!-- 1-5 -->
<ul>
<li>Item 1</li>
<li>Item 2</li>
<li>Item 3</li>
<li>Item 4</li>
<li>Item 5</li>
</ul>
</div>
<!-- 6-10 -->
<div>
<ul>
<li>Item 6</li>
<li>Item 7</li>
<li>Item 8</li>
<li>Item 9</li>
<li>Item 10</li>
</ul>
</div>
<!-- 11-15 -->
<div>
<ul>
<li>Item 11</li>
<li>Item 12</li>
<li>Item 13</li>
</ul>
</div>
Can that be done using a repeating region behaviour. Is it even possible?
Any help would be greatly appreciated.
CraigRBeta Tester
how many sets of 5 are you looking to produce ?
for three sets you could do this with 3 recordsets using the LIMIT clause to select the number of rows and the offset
ther may well be other ways
phebberd116714
The number of sets would depend on how many items were in the database at any given time. So I don't think it can be done by different record sets.
But thanks for the reply.
CraigRBeta Tester
depending on how your data is grouped, there is another option which could work for you, (with a single recordset)
take a look at this link and see if it works for you.
post_Create_nested_lists_from_a_recordset__PHP_-16720.html
phebberd116714
Thanks Craig,
I took a look at the article but that won't work either. If there were say, 8 items under a date, then it would show 8 rather than splitting into groups of 5.
What I eventually want to achieve, is create a scrollable list of images (these would be related to another main image by type.) For instance, choosing a tile style would show that main image and underneath would be a scrollable list of similar tiles.
I found a jQuery scroller (index.html) that achieves the scrolling I like but it works by having the images in groups of 5 inside separate div containers.
So, any ideas?
you would need to hand code this manually in the results set.
the basic gist of the code would use a counter that you increment inside of the loop, if it equals five start a new div:
something like:
<?php $count=1; ?>
<?php if($count==1) { ?>
<div>
<ul>
<?php } ?>
<?php do {
<li><?php echo $row_rsname['column']; ?></li>
<?php $count ++; ?>
<?php if($count==6) { ?>
<?php $count=1; ?>
</ul>
</div>
<?php } ?>
<?php } while ($row_rsname = mysql_fetch_assoc($rsname)); ?>
This is just the basic idea, you may need to adjust the code to get the specific results you are looking for.
phebberd116714
Thanks Jason,
When I put in your code Dreamweaver was showing an error (attachment 1) and I got no results.
I added a closing tag after the <?php do (attachment 2) and that does split the results into blocks of 5.
But it is not adding the beginning div and ul tags for the subsequent sets of 5 and nothing except the li tags on a set less than 5.
The result:
<div>
<ul>
<li>image1</li>
<li>image2</li>
<li>image3</li>
<li>image4</li>
<li>image5</li>
</ul>
</div>
<li>image6</li>
<li>image7</li>
<li>image8</li>
<li>image9</li>
<li>image10</li>
</ul>
</div>
<li>image11</li>
<li>image12</li>
<li>image13</li>
<li>image14</li>
<li>image15</li>
</ul>
</div>
<li>image16</li>
<li>image17</li>
Can you point out where I am going wrong.
Thanks in advance.
CraigRBeta Tester
try this instead...
<?php $count=1; ?>
<?php do { ?>
<div>
<ul>
<?php } ?>
<?php $count ++; ?>
</ul>
</div>
<?php $count=1; ?>
<?php } ?>
Thanks CraigR, that should fix it.
CraigRBeta Tester
I love this forum, I'm always learning of better ways of doing things
