Data Assist Tutorial Files
Thread begun 2/25/2011 1:20 pm by qureshisalman422919 | Last modified 2/28/2011 9:18 am by Jason Byrnes | 2579 views | 3 replies |
qureshisalman422919
Hi
I just downloaded and installed DataAssist and am trying to follow the tutorial which used some sample files. I would like to know if I need to create a MySql database to make the tutorial work as I can't seem to find a database with the files
Which tutorial are you following? What is the name of it?
qureshisalman422919
Tutorial
It is under the Getting Started Guide: Data Assist (PDF)
In the download center, go to the Data Assist download page, at the bottom is a section titled:
Solution Recipes: Support Files
download the
SiteAssist and DataAssist: Solution Recipe Files (1,924 KB)
you really only need the blue sky database in the data sources folder for the DA2 getting started guide.
